Inverted 2-Stroke Problems
Old 07-29-2004 | 07:10 AM
Default Inverted 2-Stroke Problems
I have a friend who has a 1.20 size 2-stroke engine and is having problems getting it to run consistantly. He wants it inverted.
When he initially installed the engine, all of the fuel would run out of the carb since the tank was so high relative to the carb. He moved the tank down but had to move the tank back from the engine about 14". Now, he can't get the engine to run consistantly.
Any suggestions?
Jim
Old 07-29-2004 | 07:54 AM
Default RE: Inverted 2-Stroke Problems
I had the same problem on my pattern ship. I installed a Perry oscillating pump and problem was solved. Hope that helps.
In Christ,
Joel Chavez
Old 07-29-2004 | 08:34 PM
Cyclic Hardover's Avatar
Either that or a Cline regulator
