GP .40 size Ultimate, engine recommendations
NC
I just finished a GP 40 size Ultimate, and installed an OS 46FX. Definitely not the power to weight ratio, I thought I would get.
I have an OS 61 FX, that I am thinking about putting on it. I would like suggestions, rather this is a good or bad idea. Also, if good idea, prop recommendations, for sport flying, with some hovering ability.
Thanks in advance.
Thanks in advance.
My Feedback: (12)
MO
The 61fx will have enough power to pull it around like you are looking for. The 61fx weighs a bit more than the 46 you will have to shift your battery pack around to bring your CG back to the right spot.
Need more power
Yup, unless you succeed in building the GP .40 sized (???) Ultimate a LOT lighter than most I have seen and flown, the .46 will fly it, but that is about all. It really is a fun little plane, just heavy for it's size (over designed). Like the above post said, the most fun one that I flew actually had a .90 Four Stroke on it. Yes, it increased the weight even more, but at least it didn't act like someone just threw an anchor overbaord every time the nose was pointed up
Lee
Lee
MO
I got the GP Ultimat bipe 40 this Christmas and plan to sell my NIB GMS 47 and NIB Fox 45 abc and buy an OS 50SX with Pitts muffler. Currently building a GP Aeromaster 60 and may do some trading to get the PICA WACO 1/6th scale kit. Currently fly the PICA WACO 1/5th scale and love its looks plus it flys real well with G23. I have a lot of options. I also have the AAMCO original Aeromaster 60 kit and deciding what to do with it.
