High Temp Silicone for Muffler
KY
I broke in an OS 91 four stroke engine the other day. I couldn't get the muffler to stop leaking. I tried to loosen and re-set the nuts on the stem to engine and muffler. But it kept letting exhaust fluid leak out. I want to try the high temp silicone I bought at the auto parts store. What should I use to get the residue off the threads? I was thinking of using Formula 44. Will that be OK? Or can I just wipe the parts off and apply the silicone?
Thanks for any help.
My Feedback: (17)
AL
I use acetone or alcohol to remove any oil residue prior to applying the silicone, most anything that would degrease the threads would probably work.
KY
Thanks for the quick responses guys.
Teflon tape? Hmm. I wish I thought of that before I got the silicone. Will it really stand up to that kind of heat? I'm not sure how much heat these engines put out. I do know that the plumbers tape needs to hold up to at least 130 degrees. Sounds interesting.
My Feedback: (21)
Yes, teflon will hold up to very high heat. I had problems with the
head-pipes coming loose, and oil making messes on the cylinder heads.
The teflon tape fixed all the problems at the same time. I was afraid the
threads would get beaten out of the head, with the head-pipe getting
loose.
Remember to retighen the nut after each flight (3 or 4 times) until the
threads "bed-in", and it stays tight.
Dave.
loose.
Dave.
Bruno:
The Teflon tape FBD mentioned will stand a lot higher temp than the RTV silicone, evedn the high temp version. Exhaust temp on a four stroke can reach 600F, so select material accordingly.
Bill.
Bill.
