TT 46 trouble
Old 12-04-2004 | 09:14 PM
Default TT 46 trouble
I'm having trouble with my TT46pro with #8 OS plug Tower muffler and 9-7 apc prop. It's always been a very reliable engine but lately it looses power. At start up it runs at 16000rpm but about 1 1/2 to 2 minutes into a full throttle run it looses power and goes down to 12000rpm? This is bad because I start up taxi out take off and 2 min later it's running weak and a little while later it dies[X(]. I've checked my fuel system and replaced all tubing. I've replaced the carb. All I can guess is maybe the bearings are bad and when it heats up it has some resistance. Is there a way to tell if the bearings are bad without pulling them out? If I'm going to go through with bearing removal then I might as well replace them. Compression seems good. Any help would be greatly appreciated. Deltatech
Old 12-04-2004 | 09:19 PM
w8ye's Avatar
My Feedback: (16)
Default RE: TT 46 trouble
You can spin the crank between your fingers while feeling for roughess. You can listen to the engine for a roughness when you flip the prop.
Try setting your engine a little richer before take-off.
Enjoy,
Jim
Old 12-04-2004 | 09:23 PM
Flyboy Dave's Avatar
My Feedback: (21)
It sounds like it is overheating in flight. Turn the main needle out 5-6
clicks more and see if it still slows down. Some engines have to be
started out real rich....richer than you would think.
FBD.
