Saito 1.80 help !!
Hi guys,
I have a Saito 1.80 engine mounted on my Dynaflite Super Decathlon and i need help for this issues :
1.- The stock muffler its too short and leave my plane with a huge mess (the engine its mounted on its side). I bought from horizon hobby a flexible muffler (Saito brand) but the measures wasnt right ... i NEED some alternative muffler, tuned pipe, flexible muffler or wathever to extend the muffler and not take hours of cleaning up my plane after a day of flying. Im from southamerica so i need some item i can buy online.
2.- Im having problems with fuel feeding to the engine, i played with the tank position and it got better but not "too good" so im looking for a onboard pump i can use to feed the engine with good amount of fuel. Some people recommends oscilating pumps, but i dont know them and i dont know where to buy one ... any suggestion to this problem ?.
thanks
Pat
thanks
Pat
Thanks but ... can you explain how this pump mounts and works ?
thanks,
Pat
thanks,
Pat
My Feedback: (16)
http://www.horizonhobby.com/Shop/ByC...dID=SAI300T73B
This is the correct Saito extension
The one with a muffler pressure tap is
http://www.horizonhobby.com/Shop/ByC...dID=SAI300T74B
There's a shorter one
http://www.horizonhobby.com/Shop/ByC...dID=SAI120S111
The thread dia is 14 mm
My Feedback: (16)
http://www.perrypumps.com/prod02.htm
The VP20 pump bolts to the back plate bolts on the back of the engine.
The fuel pressure is adjustable by turning the blue nut.
Enjoy,
Jim
Enjoy,
Jim
Mhhh wow ... now im preocupied.
Another alternative its a Slimline Pitts Muffler, US$ 99 but im not sure if it will enough for messy oil throwing long from the fuse ...
Richard, i know but when the stock muffler its too short that almost dont protude outside the cowl, its a problem dont you think ?
