Fuel tank question
Old 03-24-2005 | 03:35 PM
MOB*'s Avatar
Default Fuel tank question
What is the maximum distance allowed between the engine and the fuel tank for a Tower Hobbies .61?
MOB*
Old 03-25-2005 | 04:24 PM
daveopam's Avatar
My Feedback: (9)
Default RE: Fuel tank question
For sport flying I think you could get away with 6-8". If you do any hovering or low RPM verticle up lines you will have a problem. A lot of pattern guys use a pump with the tank on the CG. That way the plane will be consistant through out the whole flight.
David
