enya throttle arm
ON, CANADA
enya throttle arm
Engine is old and been crashed. Throttle arm broken off. Have made a throttle arm out of servo arm which should work ok. Question-- Will the homemade throttle arm tolerate the heat of the engine where it is fastend to motor?? I am totally inexperienced with motors and would app. any info or opinions. thnx--geezer
RE: enya throttle arm
i made a throttle arm from those metal peaces that come off the back of a computer case when you want to install a PCI card. a little grinding, bendind and drilling and works like a charm. BTW it was for an enya. when i get home ill post a picture.
