Can a YS 140 Sport be started by hand ???
I start all my Saito and OS four strokes by hand. Can the YS 140 Sport be started by hand cranking???
My Feedback: (41)
RE: Can a YS 140 Sport be started by hand ???
I guess you could but you need to pressurize the fuel tank first by flipping the prop a dozen times. Then prime the engine as normal. I always use a starter on my YS 63, it's easier.
ORIGINAL: mar345
Uh OH !!! Looks like I put this question on the wrong forum. Maybe a moderator would be good enough to move it to the "glow engine" forum.
I can start my YS110 by hand, I will back flip it by turning the spinner backwards. However, the first start of the day will be by electric starter. This is not to pressurise the tank. After I land I will always release the pressure so the second time starting by back flipping has nothing to do with getting the tank pressurised. I will open the throttle a little to get it started, at an idle setting it does not want to start as well.
My Feedback: (24)
ORIGINAL: mar345
ORIGINAL: mar345
What method do you use to prime the engine ?
Once the engine has its first start of the day, it will just hand flip start without priming just like a small two-stroke.
OK, So let me see if I have this right. To start the YS 140 Sport by hand, prime the engine by flipping the prop eight to ten times with the throttle wide open. Reduce throttle setting to a little more open than idle. Apply power to the glow plug and flip the prop backward against compression so that it kicks over.
