maxgum xls 46 question
i have a magnum xls 46 on my trainer. the engine runs extremly well but when i try to idle the engine it will quit after 20-30 seconds. my landings are all dead sticks. i'm using 5% magnum fuel, robbe no 3 hot plug and a 11x8 graupner prop (very pleased with this prop)
BTW the only time i can keep my engine idling is when the tank is almost empty.
regards
red
regards
red
NJ
RE: maxgum xls 46 question
make sure your low speed needle is not vibrating out. I have a .28 mag xl and I used teflon tape to remedy this problem . Some will say don't use teflon tape but the choice is yours. You can also put a piece of fuel tubing to keep it from backing out , but it will not keep it form moving in. GL
stefache' binne'?
sorry for my poore romanian...
46manum xl - which is the asp46 which is the TH46 are great chinese motors.
1. magnum/omega 5% is the only fuel for this chinese sweetahrts...
2.send me u email and i'll send do the manual.
3. air neddle should be opend 1/2 to 1/3 of a trun while using the 5% fuel. if go to 10% u can keep more idel with the needle.
4. put a OS F type plug. it will help u to keep the RPM's.
enjoy
gadix
enjoy
gadix
