prop help
VA
I just made a 48" wingspan delta wing foamy, I have an OS26FS I have mounted on it, I don't know what size prop will work best in this application and I need HELP! overall wt. with all gear installed is 3 1/2 lbs. I have posted this same inquiry in several forums with absolutely NO response, someone out there has to be able to help out of the masses of people who use this site .thanx in advance ericthetree.
VA
thank you, Dave. I have a 10/6 and I'm headed for the garage right now to try it out. do you think I should set this bird up with an elevator and ailerons. or would a flaperon set-up work best?
My Feedback: (102)
Speaking from Saito .30 experience I agree. MY Saito .30 was on a heavier Sig LT .25 with a nose gear, I alternated between a 10x5 and a 10x6 depending on the grass length where I was flying at the time. I used Graupners in both cases. Those nice wide blades really work well with fourstrokes.
My Feedback: (21)
On a small winspan like that, I think I would go with flaperons....
....it's gonna be real touchy either way. Set your alighnment as good as
you can by eyeball....and keep the throws small. That thing will be a handfull
till you get it trimmed out. If you have expotential....set it at 40% negative at first.
Dave.
Dave.
VA
i'll try the elevons and let ya'll know how it went, just back in from garage and the 10/6 seems fine,nice idle, good full throttle.thanx again for the help guys,ericthetree.
