Shame on me, 1st MDS problem
My Feedback: (8)
CO
I am a strong advocate of MDS engines because I have flown many with never a problem even when using the older C1 carb until now.
I picked up another MDS .58 and it has exhibited many of the same problems that others have experienced and complained about. My MDS .58 would lean out and overheat and die in flight. I would have to richen the mixture so much that the plane would barely take off and then once off the air, the engine would lean in flight to a normal setting.
I checked every possible cause of this problem three times and I can't find a cause for this occurence.
I finally purchased a new carb from Just Engines in England and my MDS .58 runs as good as my other MDS engines. I thought I'd share this with those who have experienced carb problems. The new carb only cost me about 30 bucks shipped and it came in a week!
Andy
PS I was too lazy to remove the cowl and carb off of my other MDS .58 to see if the swap would verify the original carb was bad.
PSS This engines LOVES an APC 11.5 x 6 prop. This is an incredible prop that gives good forward speed and sufficient take off thrust.
Andy
My Feedback: (8)
CO
RE: Shame on me, 1st MDS problem
It was a J'en carb and it works great! I still have to dial in the low end a bit, its slightly rich, but will wait when engine has more time on it. I ran it for about 4 flights today (10 minutes apiece) and am very pleased with its performance.
