K & B muffler problem
Old 08-10-2002 | 11:15 AM
bignasdy's Avatar
Default K & B muffler problem
dont tighten it so tight for one. you snug the bolt, then lock it in place with the nut. If the prop is ballanced, and the engine is mounted properly, there shouldnt be any problems.
david
Old 08-10-2002 | 08:01 PM
Bignasdy is right. As the muffler heats up, it expands, and the screw might not be able to hold that much stress. If you've ever tightened a muffler before it cools off you'll know what I mean. Get it just tight enough to hold it together without any slop.
Old 08-14-2002 | 06:54 AM
Banned
Locktite, or Permatex high temp gasket sealant to help prevent the nut from vibrating loose before the muffler expands from heat.
