Most powerful
Old 06-28-2005 | 08:48 AM
Default Most powerful
Whitch one of theese two are the most powerful engine ? Super Tigre 51 or Os 46 ax
Old 06-28-2005 | 09:10 AM
w8ye's Avatar
My Feedback: (16)
Default RE: Most powerful
It hard to compare these two. The timing and rpm range of the two engines is different.
Enjoy,
Jim
Old 06-28-2005 | 06:22 PM
I've flown identical draggy airframes with each of these engines. The ST .51 will pull a bigger prop more happily than the OS AX.46. A 12x6 is not out of the question with the ST engine. For this type of airframe, the two engines perform similarly.
In a sleek ariframe, the OS appears to have much more propensity to rev and produce speed and thus would have more peak power.
Where torque turning large props is important, consider the ST. For outright horsepower, consider the OS. Both engines have good handling charcteristics.
