SMOKE: will this work??
Old 10-18-2002 | 09:06 PM
Default SMOKE: will this work??
Hi...
I was wondering if any of you have tryed to use smoke fluid for "disco-smoke-generators" as a smoke oil..??
Thanks for youre time..
Sandman
Old 10-23-2002 | 06:46 PM
Anyone..???
Sandman
Old 10-23-2002 | 09:57 PM
never heard of a disco smoke generator, why, do have like plenty of fluid left over from the 70's??
Old 10-24-2002 | 02:26 PM
MinnFlyer's Avatar
I do a lot of theatrical work and I know that those fog machines work on several different principles. So it would depend on which type of fluid you have. Is it designed to be heated, then released into the atmosphere? If so, then it might work in a plane, providing the muffler produces the right amount of heat to activate the fluid.
Of course, no one has ever tested what that type of smoke will do to your covering, foam, etc.
So, to answer your question... Will it work? Maybe.
Old 10-24-2002 | 05:07 PM
Hi ..
I myself dont have a clue to how they work, but the they sure use some power to produce smoke, 700-2000W is the norm.
I guess there is only one way to know, and that is to test it. I*ll give it a try and let you all know.
Sandman
