Fuel efficient engine: help wanted
Old 10-21-2002 | 10:08 AM
My Feedback: (16)
Default Fuel efficient engine: help wanted
Folks:
I am looking for details on the most fuel efficient engines in the 90-and larger class. I am looking for a low rpm, high torque engine, either glow, or glow-converted-to-gas, that produces 2 hp or more. Two stroke or four stroke, does not matter: just looking for a long endurance engine.
Please email me directly, if possible: [email protected]
Suman
Lawrence, KS
Old 10-21-2002 | 11:51 AM
Hobbsy's Avatar
My Feedback: (102)
Default Fuel effecient
There have been several posts on here about the Webra 120 being fuel effecient, I have one that is barely broken in and can only say that it is very smooth running and idles really well and has a good reputation for being light and powerful. Runs best on 5% nitro. 3.2 HP
Old 10-21-2002 | 12:02 PM
jettstarblue's Avatar
Default NOT A FUEL HOG
Have you tried a Davis diesel head for your engine, or looked into converting an engine with a Davis diesel head?
In the past we have run a couple of these, and they really do (almost) double run time.
We flew an FP .40 with one and, it made the 40 min. round trip with a reg. sized tank- granted, this was in a LARGE modified sailplane, but we had a lot of fun taking it on road trips!!
Jetts
Old 10-21-2002 | 12:16 PM
My Feedback: (16)
Gentlemen:
I have used diesels for years. I am looking for engines that rival, or better diesels in fuel consumption. The problem with diesels is also that they are not made in the large sizes I am interested in.
Thanks for the info, and please keep the responses coming.
Suman
Old 10-21-2002 | 12:28 PM
Default WOW
Lots of luck guy, if you find something like that let me know.
Jetts
Old 10-21-2002 | 02:50 PM
Mvvs makes .61 diesel that has great power. Capable of swinging large props ~ 15 inch with ease. A large diesel produced by a manufacturer.
bobi
Old 10-22-2002 | 12:07 AM
PlaneKrazee's Avatar
My Feedback: (14)
Default hobbys
Maybe you can share the fuel consumption of your engine with us.
I ran my OS 160 FX at WOT with a 17X8 prop at 9400 rpm on a eight oz tank for 5 minutes 20 seconds after I had about 1/2 gallon thru it. This was peaked rpm and therefore less fuel consumption than when tuned to fly.
Brian
Old 10-22-2002 | 12:29 AM
My Feedback: (16)
Turning a 17x8 at 4000 rpm, the 60-size PAW diesel ran about 2.5 minutes on one ounce of fuel. I was disappointed, considering my Irvine 40 can turn a 12x6 APC at 6000 rpm for about 15 minutes on one ounce.
Suman
Old 10-22-2002 | 02:24 AM
I'm one of the guys saying the Webra is fuel efficient. I have never measured it. I fly mixed turn-around aerobatics. 15 minutes of flying uses about 10 oz of fuel.
suman, I think what you need is a gasoline engine. Take a look at the MVVS 1.6 petrol. If you're really energetic, and can accommodate a poor power to weight ratio, try a Ryobi four stroke trimmer motor. I think you need spark ignition and the ability to run lean A/F ratio. A tuned pipe may help the two stroke if tuned for moderate rpm. That would be a big long pipe for the MVVS.
A model diesel is different than an "regular" diesel. The fuel is not injected into the cylinder an there is no control of ignition timing. It's more like planed pre-ignition. :stupid:
Old 10-22-2002 | 02:57 AM
If you're thinkin about the webra 1.20 and want to get maximum fuel economy, you could get a davis diesel head for it. They make a few of conversion heads for .90 and greater size O.S., supertigre, webra, rossi,and moki engines.
