NIB Engine please help!
FL
Hello friends,
Yesterday I bought an NIB OS 25FX from a local hobby shop. When I came home instilled some after run oil drops and installed a prop.
I begin to turn the prop by hand, but when piston is in up position, there is a lock something like a short stroke, then I need to apply some force to complete the turn.
I did put apart the cylinder head and cover plate and inside the engine seems to be new. When I release the cylinder head screws, this lock or short stroke disappear.
There is something wrong with this engine, should try to break in or should to return to store?
Thanks in advance.
Javier
This engine is normal. It's an ABC design. Aluminum piston, chrome plated brass cylinder liner. This type has the liner ground in a taper, with a slightly smaller diameter at the top. When the engine heats up, the top of the liner expands to the proper clearance. You MUST break in this engine in an only SLIGHTLY rich two stroke mode. It MUST come up to operating temperatutre to properly break in.
Dr.1
Dr.1
My Feedback: (12)
ORIGINAL: Javier-RCU
) on page 7: With these engines, the piston will feel tight at the top of its stroke when the engine is cold. This is normal. The piston and cylinder are designed to achieve a perfect running clearance when they reach their intended running temperature.
FL
[/quote]
From the owners manual (that paper thingy that many people toss aside and ignore
[quote]
You are RIGHT!
Some times one think that knows all... This is my first experience with a little engine. Your advice is well accepted!
Javier
) on page 7: With these engines, the piston will feel tight at the top of its stroke when the engine is cold. This is normal. The piston and cylinder are designed to achieve a perfect running clearance when they reach their intended running temperature.[quote]
You are RIGHT!
Javier
