enya 53 thread size
Old 09-10-2005 | 02:27 AM
Default enya 53 thread size
Can anybody tell me what is the trhead size of muffler header assembly in a enya .53 4C?
Do you know if it mach any os or other brand muffler?
thanks in advance
Old 09-10-2005 | 01:35 PM
Default RE: enya 53 thread size
[b]Can't tell you on the Enya, but once you measure it the Saitos use 10 mm on the FA-40 and similar engines, the FA-65 through FA-100 use a 12mm thread, then the FA-120 and larger use 14mm threads in the exhaust ports.
The Magnum and OS use 11mm pipes.
Hope this helps.
Bill.
