Need help tuning my engine
Old 09-10-2005 | 09:00 AM
Default Need help tuning my engine
Can someone help me adjust my settings on my carb OS 21 VZB V-spec. It stalls when I give it gas? I also want to re adjust the settings to were they need to be they have been played with. I want to make sure that I am not running to lean.
Old 09-10-2005 | 09:05 AM
w8ye's Avatar
My Feedback: (16)
Default RE: Need help tuning my enigine
When accelerating from idle does it stumble, mess around and then quit? If so the idle is too rich.
If trying to accelerate and it just quits, the idle is too lean.
Old 09-10-2005 | 09:10 AM
Default RE: Need help tuning my engine
Thanks w8ye, when I give it gas it goes about 1 foot and then dies. Do you know how far out all the settings need to be?
Old 09-10-2005 | 11:00 AM
w8ye's Avatar
My Feedback: (16)
Can you identify the low speed mixture setting needle?
Old 09-10-2005 | 11:45 AM
is that the same as Mixture control valve?
Old 09-10-2005 | 05:17 PM
On most carbs are the screws mostly out or are they in a lot?
Old 09-10-2005 | 06:08 PM
w8ye's Avatar
My Feedback: (16)
Somewhere between 1 1/2 to 2 1/2 turns is normal for most carbs.
Old 09-10-2005 | 06:12 PM
w8ye's Avatar
My Feedback: (16)
Download the manual here... http://www.osengines.com/manuals/21vzb-vspec-manual.pdf
The high speed needle is the one that sticks out at an angle.
The lowspeed needle is in the center of the throttle barrel on the same side of the carb as the high speed.
