cordless drill for a starter
Old 09-11-2005 | 11:07 AM
Default cordless drill for a starter
just wondered if anyone has used a cordless drill for an engine starter
Old 09-11-2005 | 11:21 AM
Default RE: cordless drill for a starter
No, but I don't see why a variable speed DeWalt wouldn't work!!
Old 09-11-2005 | 11:38 AM
[b]I've heard oftheir being used as starters, the only problem is that for some engines they just don't turn fast enough.
Bill.
Old 09-11-2005 | 01:33 PM
BarracudaHockey's Avatar
Helicopter guys have been using them for years with the hex start shafts.
Old 09-11-2005 | 02:18 PM
RC-Captain's Avatar
they make cordless starters , I don't think a drill will work with a nose cone.
Old 09-11-2005 | 02:54 PM
My Feedback: (12)
I use one, but it is a tad too slow, you can't keep it on, you need to back off after you get the prop spinning
Old 09-11-2005 | 03:33 PM
I have used a Mikita Cordless drill with 18 volts. As others have said they are a bit slow, but work alright for a 4 stroke if they idle low enough
Old 09-11-2005 | 04:28 PM
Rupurt's Avatar
IThey work well for heli's, I was going to make an ally thing to hold the silicon starter cups but haven't got round to it yet, i can let you know how it works when i do.
Old 09-11-2005 | 07:26 PM
For what it is worth my Black and Decker cordless drill has two speed ranges: 0 – 400 RPM and 0 – 1300 RPM.
My electric starter has a cup with a 1/4” thread that could easily be chucked in a drill.
I have not used the drill as a starter but would not hesitate if it were needed.
Bill
Old 09-11-2005 | 08:46 PM
My Feedback: (12)
Yes, most of the rc starter cups use a 1/4x20 thread hole, so just get an allen bolt that size and put it through the cup and then chuck it in the drill.
Old 09-12-2005 | 07:10 AM
desert flier's Avatar
Hi I have a 18 v cordles drill with a cup wich i made in the lathe thought it would work on my OS la 46 but it turned it over but the motor would not fire. Flicked it over with a stick and it fired straight away I have now orderd a starter
Old 09-12-2005 | 11:46 AM
proptop's Avatar
My Feedback: (8)
FWIW....
Aside from the above mentioned Heli's, my Schumacher Fusion's TT .21 has a backplate mounted assy. that uses a ball driver chucked in a cordless drill to start.
It turns over slowly at first, but as the fuel gets to the bearings, etc. they loosen up, then it spins plenty fast enough.
