Club Enya
Old 02-21-2010, 11:40 AM
  #851
NM2K
My Feedback: (14)
Default RE: Club Enya
ORIGINAL: lavagrit
today,I buy a new enya 53-4C . it is look very good . Next time ,I will buy a enya 155-4C.
I own an un ran Enya 53-4C engine, but I used to help others that owned them, which is why I ended up buying one. They ran great and they were extremely durable.
I owned an ran the Enya R 1.20-4C, the predecessor to the 155-4C and must say that it was strong and reliable too.
Ed Cregger
Old 02-21-2010, 08:32 PM
  #852
Ram Jet
Ram Jet's Avatar
ORIGINAL: lavagrit
I've heard nothing but good things about the .53.4C. Break her in nice!
Regards,
Bill
Old 03-01-2010, 06:10 AM
  #853
aeronca2004
Hi is anyone able to upload or give a link to the article/review of the Enya Vt240 i believe either Clarence Lee or Peter Chinn reviewed it when it was released in 1986. I wish to keep a copy of the review with my engines.
Old 03-01-2010, 12:27 PM
  #854
rrengineer
rrengineer's Avatar
Well, I can't give you a link, but I can attach some scans as I have a copy of the article. If these don't come out well, PM me and I will send larger copies.
Mike MacLean
ID:	1389222   Click image for larger version
ID:	1389223   Click image for larger version
ID:	1389224   Click image for larger version
ID:	1389225   Click image for larger version
Old 03-02-2010, 05:27 AM
  #855
aeronca2004
Hi thanks for the quick reply i see the images unfortunately too small on my screen i have sent you a pm with my email thanks so much for your help. Andrew
Old 03-02-2010, 10:25 AM
  #856
blw
blw's Avatar
aeronca2004- try saving the pics and enlarging them with a graphics program.....? They come very good on this end.
Old 03-02-2010, 11:53 AM
  #857
martin_solo
Just an update about my post # 795
Initially I had a Sullivan 2 Oz tank installed but because of the overflow bump the tank was mounted to low and that was the main problem. Then I got a Chinese made 90ml fuel tank that had a flat top, but it was deeper and to make things worse it crack in the seam and cause all sort of problems.
Now I got a Dubro 2 Oz tank that has a flat top and I could mount it as high as possible. The supplied silicone fuel tube is too thick and it will not flex all the way for the clunk to pick fuel every where. So I replace it with 1/8 fuel line from www.texastimers.com to assemble fuel pick up line, it’s so flexible that when I tip the tank with the back end up, the clunk fell down to the front. I made a much lighter clunk for it because I was afraid it could tangle inside.
I set the AirBleed 100% open and that solved the transition problems I was having (Thank Jim!).
With this new tank setup it is still siphoning back a bit, but not as bad as before. I got the hang of it and not having any trouble getting the engine started.
Now the Enya 09 is working great! I started with an MAS S2 7x6 then APC 7x6, which was not as good and then the MAS S2 8x4 which worked much better. With the 8x4 I got much better acceleration and taking off was way much better.
The interesting thing about this engine is that with the 8x4 I could make fly bys as fast as with the 7x6! I couldn’t believe it my self! I always thought smaller diameter props with more pitch would give a lot more top end speed.
So here we have another Enya 09 user that can attest it works better with an 8x4 prop.
Unfortunately my Cloud Ranger end up very heavy, the wood in the kit was terribly heavy. I now keep thinking how awesome it would be if I had a lighter plane. The little thing comes fast for landing and when I cut the power it will keep on going fast.
I may scratch build another one, changing the nose design so I can mount the fuel tank higher and use a thicker airfoil so it can be flown slower.
I will now try other props, glow plugs and also try to mount the pressure nipple no the muffler closer to the engine to get more pressure.
Thank you all for the help! I had a blast this weekend with my first glow R/C model.
Martin
Old 03-22-2010, 02:39 PM
  #858
EyeflyRC
My Feedback: (147)
A question for Enya four stroke rebuilders. How do you tell that the crankshaft bearings need to be replaced? How much play is ok when you rock the crank up and down? Bearings are smooth and engine runs fine with no leaks at crank.
Old 03-22-2010, 06:52 PM
  #859
Luna_Rendezvous
Luna_Rendezvous's Avatar
I rebuilt an eBay bargain, it had noticeably crunchy bearings, and once rebuilt the new bearings had very little play and it's was almost impossible to detect any lateral movement. I bought genuine Enya replacements, and was surprised how smooth they were.
By your description they sound fine, a little play is nothing to worry about.
Mike.
http://www.youtube.com/watch?v=xHYmE4NGEzY
Old 03-22-2010, 08:58 PM
  #860
EyeflyRC
My Feedback: (147)
Thanks for the input. When I rock the shaft up and down I get what feels like about 1/32nd play. Is that ok?
Old 03-22-2010, 10:20 PM
  #861
Luna_Rendezvous
I wouldn't be too concerned with that amount of play, so long the engine is performing and not dead sticking, I only replace bearings if they are rough and gritty.
Old 03-22-2010, 10:56 PM
  #862
Luna_Rendezvous
I'm used to thinking in metric, so I just broke out my dial calipers, if you are seeing 1/32nd movement at the crank then yes that might be time to change the bearings, but if you're seeing that at the ends of the prop then don't worry about it.
Mike.
Old 03-23-2010, 06:48 AM
  #863
EyeflyRC
My Feedback: (147)
Mike,
A rough measurement at the end of a 12 inch prop shows crankshaft run-out of around .044 or a little less than 3/64 of an inch. This was done by holding the engine in a vise and rocking the prop perpendicular to the shaft. Would you expect any damage to the engine if I continue to use it without changing the bearings at this time?
Andrew
Old 03-23-2010, 07:40 AM
  #864
Luna_Rendezvous
I'm pretty certain that sort of runout is within spec, if you need confirmation, then by all means contact Ken Enya, he will be more than happy to answer this type of question, his email addy can be found here... http://www.enya-engine.com/store/ind...ain_page=index
Old 03-23-2010, 07:41 AM
  #865
EyeflyRC
My Feedback: (147)
OK, Thanks for all of the help.
Andrew
Old 03-23-2010, 07:45 AM
  #866
chistech
I just replaced the bearings on an old 46-4c that was given to me. It too had a lot of play in the bearings but seemed to run fine. Not sure how your engine is made inside,(46-4c crank pin goes through the connecting rod into the cam drive shaft plate) but too much play would make the connecting rod wear on the crank pin prematurely I would think. Bearings are cheap when you think about it and are easily available. Parts like connecting rods and pistons for older engines are not. When I replaced the bearings the engine which seemed to run fine picked up another 3-400 rpms so they were actually affecting the performance of this motor.
Old 03-23-2010, 11:25 AM
  #867
Ram Jet
Ram Jet's Avatar
ORIGINAL: chistech
I recommend rcbearings.com. They have it all and are very inexpensive.
Bill
Old 03-23-2010, 11:31 AM
  #868
Jeff Worsham
My Feedback: (28)
Just went to rcbearings.com and found the domain name for sale. Are they still in business?
Old 03-23-2010, 02:46 PM
  #869
Ram Jet
Ram Jet's Avatar
ORIGINAL: Jeff Worsham
Sorry, I think it's my problem. Try "rc-bearings.com"
Regarda,
Bill
Old 03-23-2010, 09:33 PM
  #870
Jeff Worsham
My Feedback: (28)
Hey- that works! www.rc-bearings.com Good selection for newer engines and I like their prices on ceramic. Last I looked, some place wanted like $60 for a pair of ceramic bearings and these guys are way less. Think I'll given 'em a try. Thanks again.
Old 03-23-2010, 11:25 PM
  #871
Ram Jet
Ram Jet's Avatar
Great. They are very knowledgeable too. They got me bearings for an eBay 3.5 K&B outboard that I don't think they run into often. They had a-little trouble at first. They ship their items like they were shot from guns.
Regards,
Bill
Old 03-30-2010, 11:15 AM
  #872
f4fwildcat17
Hi - this may be a dumb question but is Enya still in buisness? I can't fine anything about the company or where to buy new engines. I find lots about parts and history of older engines. Am I not looking in the right place?
Old 03-30-2010, 12:01 PM
  #873
landeck
Yes, they are very much still in business. You can order direct:
http://www.enya-engine.com/index_E.htm
US service is provided by:
http://www.bj-model-engines.com/home.html
Bruce
Old 03-30-2010, 02:27 PM
  #874
f4fwildcat17
Thanks for the help, I hear Enya is the best for 4cy and it seems that would be the way to go.
Don
Old 03-30-2010, 02:45 PM
  #875
landeck
Don, I have a 80 4C that is 20 years old and still turns a 13x6 prop at 10,000 rpm. They are good engines.
Bruce
