Club FOX!
#2976
RE: Club FOX!
The carbs cost me $49.95 each,plus some postage charges too. I had ordered some other stuff along with a engine and some other stuff thatI got too. The carb cost is reasonable in my opinion. A Perry carb costs as much or more. OS carbs are priced way way up there in comparison. Now granted the cheap carbs like for ASP engines can be had for low prices, but you run the risk of getting an acceptable to use carb or a bad carb. The Fox carbs do work really well.
Here is a Fox carb to ASP .61 adapter I made a while back. The carb sits up higher, but the engine would be for a side mount installation anyway.
#2978
RE: Club FOX!
A couple of years ago I went to the Fox facility in person and paid only $40 for the new carb. So, if you happen to be passing by Fort Smith, AR, drop by and buy your carb. While you're at it, their technician will install, run, and tune the engine with the new carb for you.l[8D]
#2979
RE: Club FOX!
Sorry about that my apologies. I didn't realize they had raised the prices for the carburetors. They are now listed at $66.95 on their website.
But if you happen to visit their factory they may still be giving discounts there too. Many years ago Fox used to have a small hobby shop of a sorts inside their factory. They used to have factory second engines at a steep discount in their store at the time. When I was last there I went pretty much crazy in the store and bought a bunch of engines and stuff. I think they may have quit selling factory seconds engines by now though.
I keep meaning to go up there and visit again. I just haven't been able too yet.
#2980
RE: Club FOX!
When I visited there, I checked out their store, but they didn't have much except old kits and some model building materials, no used engines.
I only bought the new carb. Later on I learned from you guys in this forum about the newer head button and ordered it from Fox. That helped cure some issues I was having last year.
Earlwb, that ASP .61 is probably the same size carb as my ASP .91? I have not had any carb troubles yet with the ASP carb, but it looks temping to try the Fox carb on it. Do you get any performance increase, or just mainly ease of tuning and throttle response?
#2981
RE: Club FOX!
Ease of tuning and throttle response was my thing for the ASP engine. The performance improvement was because it is a better carb than what was on the engine at the time. The ASP carb was too rich through the mid range, and the intake venturi bore was too large, resulting in poor fuel draw, such that the engine had to be run rich at the beginning of a flight and it would lean out a lot as the fuel tank emptied out. The Fox carb with a smaller bore improved fuel draw but didn't affect performance. the ASP carb bore was so large that the engine was at full throttle at a little over 3/4 throttle, thus going WOT didn't gain any more speed. Technically any other carb would have likely worked OK too, say a Perry Carb for instance or a OS carb too. In my example engine the stock ASP carb bore was too large and it was too rich through the mid-range. Now I could have maybe studies the ASP carb more, and maybe reworked the needle tapers or made new needles for it or something, maybe even a intake venturi restrictor, but I just didn't feel like it at the time. But you are correct in that maybe the carb was used on their .91's, 1.08 or even the 1.20 engine for that matter.
#2982
RE: Club FOX!
ORIGINAL OP: RaceCity Enough ranting about this foreign stuff... Let's talk about real AMERICAN IRON!! There's nothing like the smell of Hot Mehanite and Castor in the morning.... .15BB, .25BB, .40BB and a slew of bushing .25's .29's and .36s.....all IRON PISTON. DUKE DUKE DUKE!!!!!!!
#2983
RE: Club FOX!
A .61 carb for $66.95? You can buy an ASP .61 for $2 more if they ever come in stock. The whole motor with muffler and carb. Not trying to push the imports or nothin, just saying. In my country everything is an import except the Quadra. As for the previous post, I am not crazy about the old Fox crossflow engines. Had the old .15, and still have the .35 stunt. The LA OS .25 will beat and match the .35. I do like my newer (somewhat) Fox .15 BB though except for the way the muffler is mounted. I goes pretty good, and better with a new Turbo type head I made up. Goes pretty good on my Sig Wonder that needed noseweight.
#2984
RE: Club FOX!
I have a pair of ASP 52's I got from a fellow in Australia for the cost of shipping. He flew from a coastal beach so there was corrosion to deal with, but the motors were very low time.
I cleaned and rebuilt them and installed a Perry when either went into my PC9 airframe. In the meantime I downloaded a review that pretty much summed up their mechanical advantages for the cost, with the sole proviso a better carb design would make all the difference. Personally, both exhibited leaning in flight to the point they would overheat. Mind you, this was my first airframe that required an inverted 2-stroke installation and several tries to mod the firewall pod to set the tank and spinner height. However, I have to agree they were problematical. Perhaps upright would have affected their performance.
#2986
RE: Club FOX!
Yes the ASP .61 engine may be quite cheap, but if you have to buy a better carburetor for the engine to get it to run right, then it wasn't a good deal after all.
#2987
RE: Club FOX!
I have run my ASP 91 for a very short time but itt has behaved well so far. Maybe they are using one size carb for 61-108. That would explain the oversizing on the 61. I bought my 91 when it was on sale for $88 with free shipping. I was also constrained to using an OS 91FX or the ASP91 because it is a copy of the OS 91FX on a plane that I bought used. We'll see how it holds up. I like their muffler, it is quiet and not too restrictive. I am concerned that it is an ABC type engine instead of ringed. Maybe it is too big for ABC?
#2988
RE: Club FOX!
There we some ducted fan engines made in .95 and 1.xx displacements using ABC cylinders and pistons. So it shouldn't be a problem. That is a plus with the Chinese engines using ABC in their engines. The engines are generally ok, but the carbs could be iffy. One thing is that the bearings may not last very long, so you want to be aware of it, in case they start to go bad.
#2993
RE: Club FOX!
ORIGINAL: earlwb
But if you happen to visit their factory they may still be giving discounts theretoo. Many years ago Fox used to have a small hobby shop of a sorts inside their factory. They used to have factory second engines at a steep discount in their store at the time. When I was last there I went pretty much crazy in the store and bought a bunch of engines and stuff. I think they may have quit selling factory seconds engines by now though.
The web prices are ususlly a lot higher than the price you would get if you called them. Sometimes 40% higher, which seems about right.
#2994
My Feedback: (102)
RE: Club FOX!
Thanks Earl, that is the stock muffler for the .61, .77 and .91 MVVS, its simple, light and has a unique throb instead of the usual two stroke shrill bark. I got a couple of those from Pe'. Pe' or Dar may still have some.
#2996
RE: Club FOX!
ORIGINAL: Sport_Pilot
More often than not, but lots of lemons compared to other brands.
ORIGINAL: aspeed
I think the Sanye (ASP Magnum AP SC etc.) motors are fine now.
#2997
RE: Club FOX!
ORIGINAL: aspeed I think the Sanye (ASP Magnum AP SC etc.) motors are fine now.
#2999
RE: Club FOX!
Got the Eagle IV back today and had a boo at the new style head button. Quite a bit different in that the squish area is retained, but the chamber is deepened with an almost vertical drop to the relatively flat dome top. If requested I can post a pic comparing old to new before I install that spare into the other engine.
#3000
RE: Club FOX!
ORIGINAL: Cougar429
