Club FOX!
Old 03-26-2017, 04:53 PM
  #4901
5skyhawk172
5skyhawk172's Avatar
Is fox gone was going too order some glow plugs from tower and there site says discontinued, Sent e mail too them never heard back.
Old 03-26-2017, 05:07 PM
  #4902
1QwkSport2.5r
1QwkSport2.5r's Avatar
Rumor has it the engine tooling is being sold off. I suspect the Fox glow plugs were made by another company and rebadged for Fox. Merlin makes fine glow plugs as does Enya. K&B plugs are available from Mecoa. McCoy is still around.
Old 03-26-2017, 05:14 PM
  #4903
5skyhawk172
Thanks 1Qwk
Old 03-26-2017, 05:23 PM
  #4904
the pope
That ratio of 2 lifetimes sounds about right !! U could aim for 3 lifetimes just to be safe .
Old 03-26-2017, 07:34 PM
  #4905
hsukaria
Well there are these nice engines that I have not acquired yet, Novarossi and Jett. I will add that to my master plan.
Old 03-26-2017, 08:35 PM
  #4906
5skyhawk172
Can i join the club, 1969 Ringmaster Fox 35 still have the engine lots of good times.
Old 03-26-2017, 11:12 PM
  #4907
Aaron L.
The Quickie Sport. Same as the engine DM12345 has:
http://sceptreflight.com/Model%20Eng...kee%20500.html
The Quickie Special. That's the version 1Qwksport2.5r mentioned as the hot one with the wild timing. Not much use on anything but a racer:
http://sceptreflight.com/Model%20Eng...20Special.html
Old 03-27-2017, 12:00 AM
  #4908
dm12345
comes with glow plug. $50 shipped . paypal ready
Old 03-27-2017, 06:47 AM
  #4909
Tildy
Tildy's Avatar
Great to see all the interest in old fox glow motors. My first fox was a 25 that ran great for many many years in a little stuck. Right now I'm working on a Kaos 60 for an Eagle 3 60.
*If anyone would have or would know where I might find a muffler extension for my fox 60 it would be much appreciated. Brodak has them on their website but no longer stocks them.
Thank you
Old 03-28-2017, 08:59 PM
  #4910
dm12345
thanks, Aaron L. i thought the piston was aluminum, but was reading otherwise. the case is indeed stamped "Q"
Old 04-12-2017, 03:54 PM
  #4911
earlwb
earlwb's Avatar
Yes Fox is gone. They are not manufacturing anything model related. I am not sure they are making anything else at this time either.
Try Merlin Glow plugs, they work really well and are priced good too.
http://www.merlinglowplugs.com/
Old 04-12-2017, 04:27 PM
  #4912
hsukaria
I like the Merlin glowplugs, they work great and are color coded for temperature range; red=hot, blue=cold, green=medium.
Old 04-12-2017, 07:01 PM
  #4913
1QwkSport2.5r
My latest diamond in the rough find is Picco glow plugs. They are damn tough and last a long time. Longevity is almost double what I get from an Enya 3. BUT they're expensive.
Old 04-13-2017, 08:22 AM
  #4914
Sport_Pilot
Sport_Pilot's Avatar
I believe they are making nothing anymore. Company closed it doors and nobody answers the phone. No Fox company not even making industrial parts anymore.
Old 04-13-2017, 08:33 AM
  #4915
hsukaria
Somebody ought to buy the manufacturing rights and tooling for the engines.
Old 04-13-2017, 10:38 AM
  #4916
1QwkSport2.5r
Why? They hadn't innovated anything in the last 20 years except their carburetor - and even with that it didn't change much. Looking at their more recent price lists and comparing to what's available now - it's hard to beat a Novarossi these days. Quality is top notch and pricing is the best it's been in 20 years. Hell, they're on-par with OS pricing (or better!) and are way better made.
It would be a big waste of money to take on the Fox brand unless you intended to completely re-design the whole "lineup".
Old 04-13-2017, 11:21 AM
  #4917
hsukaria
Novarossi engines don't seem that big a bargain to me: https://www.planethobby.com/collecti...9mm-carburetor
$100 more than other engines and that doesn't include a muffler. Plus I see that there are a lot of "Sold Out" items, it could be that they are getting out of airplane engines?
Old 04-13-2017, 11:35 AM
  #4918
F4 Phantom blue angles
F4 Phantom blue angles's Avatar
I flew a fox .40 back in 1989 and it screamed.and it only got better after each run.The Fox,Eagle .60 I never had alot of luck with it. It ran Ok,but needed alot of lubrication maybe I just wasnt tuning it right. I think it was the Fox .46 that I had,which was ringed, didnt have the power and performance that the .40 had. This is only my opinion. I ran a 10/8 prop on both and the .40 out performed the .46. If .40's were still around,I would by a couple of them. I think the reason is ABC vrs. Ringed.
Old 04-13-2017, 12:14 PM
  #4919
1QwkSport2.5r
The "bargain" isn't necessarily the price tag solely. Everybody equates "value" with the price tag. The value comes in with performance and longevity.
Planet Hobby has some better pricing than Novarossi Direct does on the aircraft engines, but I've run some Novarossi car engines and they are absolutely fantastic. I hadn't checked the pricing on the aircraft engines lately - pricing has gone up a bit in the last month or so. I have a feeling the aircraft engines don't move as fast as the car engines do and is probably why the pricing is higher on the aircraft engines.
Old 04-13-2017, 12:20 PM
  #4920
1QwkSport2.5r
The .46 was ABC. The .45 and .50 were ringed. Most of the lapped .40s I had ran fine, but were. I barn burners. They were the compact series though and probably why they weren't stellar. The big case .40 was much better in performance.
I still have a compact .40 ABC that runs okay. I got it new/unrun. Seems to run okay although the piston seal is not good. I'm betting the piston or liner or both aren't totally round. I suspect the quality slipped with the later production engines. The lapped pistons were fitted significantly better than any of the ABC Foxes I've had in my hands.
Old 04-13-2017, 12:35 PM
  #4921
hsukaria
I have 3 compact 40s with lapped pistons and although they are not high performance engines, they have very good power to weight output and can be used on smaller planes around 3 to 4 pounds weight with great results. I have some ringed 45's that might not be equal to modern day 46's but they are decent and run on low nitro. I recently bought a used Fox Hawk 60 ringed that has similar characteristics to the compact 40s in that it is a very compact but is old enough that has performance of a modern day 46-50 engines. But I expected the performance of the Hawk to be lower since it is a fairly old design. Regardless, it is a very nice behaving engine that I am considering an old classic pattern plane for it. I just don't know which plane though.
Anybody have a recommendation of what plane would be good with a Fox Hawk 60?
Old 04-13-2017, 12:40 PM
  #4922
I absolutly agree, The lapped engines ran great because of the tight tolerances with the piston and case, In my opinion,ringed engines run more smoother than lapped engines,especially at low idle. But they all work fine. Thats what makes this hobby fun!
Old 04-13-2017, 01:01 PM
  #4923
Charley
None of you guys seem to get where Duke was coming from with the .46, .50 & Eagle IV .60 engines. He tuned them for torque. To get the best out of them you had to use a big bat. Everyone uses RPM as a guideline and all want a 10" prop. Stupid.
CR
Old 04-13-2017, 02:53 PM
  #4924
earlwb
earlwb's Avatar
It is possible that MECOA bought the tooling. But maybe not as they pretty much didn't have any parts left either.
But for Fox Manufacturing, his kids and grandkids just were not interested in continuing the company. His wife got to old to continue and one of his relations ran the company after he had retired from his previous job. But he got too old to keep it going too. Thus there wasn't anyone to keep the company going anymore.
Old 04-13-2017, 03:37 PM
  #4925
1QwkSport2.5r
CR
Don't forget that Eagle IV .60 out ran a Rossi .60 on a small prop which seemed to be the benchmark for Rossi and the like of the era.
Lets face it though - a lot of guys are opting for 4-strokes where a .61-.91 2-stroke is or would be the go-to engine size. In the discussion of bringing Fox back or whatever - It wouldn't make much sense unless they came out with a 4-stroke engine of their own design (and hopefully not ugly like many of their engines) in a few different displacements. Then they might have a fighting chance at making some sales.
You might think I'm stupid - and that's fine. I don't care. Do notice that I never referenced any specific props or rpm. Companies like Novarossi make several different versions of a given displacement for different purposes. There are at least 3 different .46 sized engines, 3 or 4 .50 sized variants and so-on. Did Fox make the Eagle IV .60 in multiple "versions" for different purposes or was it always a one size fits all? Oh wait, you could change head buttons, re-profile needle valves and so-on to tailor your Fox to run.. that sounds kinda stupid to me.
