Carburation problems
I have a stick with motor tower hobbies .46 ball bearing ABC. - today's I had problems with the carburation, to the regular one the needle of high and to thoroughly hurry, the motor went out, for what I also had to regulate the needle of low, being presented the same problem in every time that I lit the motor. - Somebody knows like I can fix this problem.
Juan Roberto
Juan Roberto
Jim
That that your you tell me I already made it and she/he always goes out in high, I also changed the spark plug, I revised the tank of fuel, the hoses and the problem persists.
Juan Roberto
Juan Roberto
Jim:
Indeed, when I will adjust the mixture, a friend sustains my airplane while I regulate the needle of high, also the needle of low, but the problem persisted.
It will be that the spark plug that I use is A-3 and he needs an A-8
Apologize for my writing in language groins, but I am learning how to speak to it
Thank you Jim for everything, perhaps another person that participates in the forum could give me an idea that he is what passes to my motor
My Feedback: (14)
If you haven't checked it as yet, it is possible that the fuel line on the fuel pickup tube in the fuel tank has either slipped off, or it has a hole in it. It is also possible that the weighted pickup tip on the end of the fuel line in the tank has slipped off.
If this is not the problem, tell me if the engine was running okay during previous flights and if this behavior of quitting is recent.
Check that the engine's backplate is tight and that all of the carb mounting screws are tight. An airleak can cause similar symptoms.
Ed Cregger
Ed Cregger
