prop
Old 10-07-2005 | 10:55 AM
Default prop
Hi. I am using apc 18*6w on my os 160. Can you suggest what prop has the fastest spool up. Pro zinger/Mens/apc/mejslik???
Old 10-07-2005 | 01:17 PM
Default RE: prop
Hi!
Any of the wooden props would be better than the APC.
I have used both APC , Menz and carbon Mejslik and 18x6 Menz is the best prop.
Regards!
Jan K
Sweden
Old 10-07-2005 | 01:30 PM
DarZeelon's Avatar
Default RE: prop
Hestvicauto,
The APC is a glass-fibre filled nylon prop, which is heavy and thus it is harder for the engine to change it rotational speed.
Any wooden prop, from Menz, Bolly, 3W, for example, will be much easier to accelerate and decelerate.
C/F props, like those from Bolly, Mejzlik and Biela are also lighter than the APC, be they are still heavier than wooden props.
