muffler right angle adaptor
Old 10-12-2005 | 05:51 AM
Default muffler right angle adaptor
I am wanting to purchase 2 right angle exhaust adaptors for my saito fa200ti (SAI65140).the problem is they are not available in Australia. Horizon have them in stock but will not ship to Australia and won't answer email can anyone help?
Old 10-12-2005 | 06:25 AM
vicarh's Avatar
Default RE: muffler right angle adaptor
fatgiraf,
I just bought one for my 91 and it is so simple I wish I had access to a lathe to make them myself. If you have access to a lathe you can cut a small block of aluminum and make two holes intersecting at 90 degrees. Then tap the holes to the same size thread as the muffler, cut the threaded part of the header and instll it on one side so you can install it on the engine head. The remaining portion of the header can be used on the other side.
You may be able to find a machine shop that can make them for you for a realtively small amount of money...
Old 10-12-2005 | 11:53 AM
Just Engines in the UK do a range of them - see [link=http://www.justengines.unseen.org/FS_mans.htm]FOUR STROKE MANIFOLDS [/link]
Old 10-12-2005 | 11:09 PM
thanks guys
