SK Engines
Old 10-28-2005 | 07:04 AM
Default SK Engines
Have many of you tried SK Engines? I am tempted to pick up the SK .50 for $50 to use on a GP Big Stik. I tried to do a search on RCU, but didn't have much luck. Only found one older thread. Does anyone have any positive or negative experiences or advice on these engines?
-Scott
Old 10-28-2005 | 07:35 AM
AMB
Default RE: SK Engines
Comes out of the same factory as Tiger shark which are a good engine a couple of years ago the TSs were fair the carb barrels were a little sticky for some reason Kange dropped the ts which is good I have the 53 and 91 ringed version. If you spend an other 29$ you \can get a supre tiger from tower and the ST carb is amough the best plus they toss in a glow starter and charger thats worth 12 or 15$
Ther was a post on this site on the SK and it was OK but the ST is a 10. IF you want to do it for $50 I think there is a place in Canada
that has TS just my opinion martin
Old 10-28-2005 | 07:45 AM
Martin-
Thanks for the advice. I'll give it some thought. Still open to input from anyone else who has flown SK engines.
-Scott
Old 10-28-2005 | 07:46 AM
AMB
martin dup post see above
Old 10-29-2005 | 01:45 PM
Turk1's Avatar
http://www.rcuniverse.com/forum/fb.asp?m=3489012
http://www.rcuniverse.com/forum/fb.asp?m=3447216
http://www.rcuniverse.com/forum/fb.asp?m=3310020&key=
Take a look at those.I am one of the first users of SK.Im impressed and happy to have them.(Both .50 ABC and .80 Ringed).
My .50 has just begun its duty on a trainer and Im so happy with it as u can read my comments on those threads.
Strongly recommend to buy it while still so cheap.
Old 10-31-2005 | 01:09 PM
Thanks for the replies. I ended up going with a Supertigre .45, simply because my LHS had one at the same price as Tower (no free glow driver). I mounted and flew it this weekend. It seems to be improving with each tank of fuel through it. I am pretty pleased with it so far.
I'll probably try an SK sometime in the future.
-Scott
