Reverse Thrust Query
Old 11-12-2005 | 08:03 AM
hnesitd1's Avatar
Default Reverse Thrust Query
Gentlemen,
re: In-Line Thrust
How do model builders get the correct thrust from the rear engine? As odd as it sounds.........is the engine spinning backwards [sm=lol.gif]or is a reverse pitch prop employed? Comments? Thanks in advance.
GDJ
Old 11-12-2005 | 08:57 AM
w8ye's Avatar
My Feedback: (16)
Default RE: Reverse Thrust Query
The prop manufacturers make PUSHER PROPS
Old 11-12-2005 | 09:40 AM
hnesitd1's Avatar
Honorary Professor
This grasshopper has searched..............................and searched...............could you please be more specific. Thanks
GDJ
Old 11-12-2005 | 09:44 AM
Hobbsy's Avatar
My Feedback: (102)
http://www.zingerpropeller.com/Pusher.htm
Old 11-12-2005 | 02:04 PM
hnesitd1's Avatar
Honorary Professor
Thankyou for your help.................cheers.
GDJ
Old 11-12-2005 | 05:34 PM
There are two ways. Either use a reverse (lefthanded) prop, or let the engine run "backwards". Latter engines need to have the ignition pickup modified, so contact your supplier if he can do that.
Old 11-12-2005 | 08:02 PM
downunder's Avatar
There are two ways to do it with the normal RC glow engine. The first is to use a prop where the blades are pitched in the opposite direction (the reverse or left handed prop as Pe said) and the engine runs the normal way. The second way only applies to an engine where the front housing is removeable (and to some rear induction engines) when you turn the front housing 90 degrees anti-clockwise. This allows the engine to run in the reverse direction as well as it would the usual way. With this system you use a normal propellor but put it on the crankshaft backwards.
Correct me if I'm wrong Pe, but I think you were talking about large reed valved ignition engines?
Old 11-12-2005 | 09:09 PM
Also several manufacturers, such as Fox, maybe OS sell reverse rotation crankshafts for a number of their engines. Changing the location of the ignition pick-up on an ignition engine would work on reed valve engines.
Old 11-13-2005 | 12:15 AM
why make it so hard, everyone knows you just put the prop on backwards..
*yes, i'm kidding!*
Old 11-13-2005 | 12:33 AM
It is best to use a reverse pitched prop on the rear engine, that way with the engines both turning in "Normal" roataion the torque cancels. If the rotation of the rear engine is reversed to use standard pitch propellors the torque is additive.
Bill.
Old 11-13-2005 | 07:53 AM
hnesitd1's Avatar
I became interested in this design while perusing Model Airplane News', on-line plan, Double-Trouble. I wasn't immediately taken with the idea but by-chance got reading up on a full scale German WWII fighter designated the Dornier 335...........the Model Airplane News plans by Tony Newsom immediately germinated. A query to RC UNIVERSE resulted in several members replying that they had hacked kits or scratch built sport planes with spectacular results. Hmmm.....maybe something interesting here, eh? The advantages are in-your-face, ie, clean wing, low drag, little torque, etc, etc................and of course out-of-the-ordinary at the field (hee hee). Al Masters has an interesting web cite for those folks interested in how he constructed a scale, Do 335 model
http://www.wingsontheweb.com/vhangar...o335_proj.html
My ambitions are far more mundane than Al's ship (GREAT web page Al). Anyway, as always RC Universe has provided a wealth of common sense, suggestions and fellowship...........what a great tool for the enthusiast.
GDJ
