Does anyone else love Enya engines?
#401
My Feedback: (102)
RE: Does anyone else love Enya engines?
Well, Enya enthusiasts, I had an Enya moment yesterday. I mounted my Enya .90 fourstroke on my Alpha 60 to replace the Saito 1.00 I had on there last year. I sold the 1.00 a few weeks ago. Much to my surprise the Alpha was way nose heavy. Today I spent some time grinding the upper inside corner of the left engine mount to move that engine back 1/2" and still had to place 2 OZ of lead in the very tail end of the fuse and place the battery at the back of the radio compartment. It still noses down pretty good when I have my bird fingers under the CG marks under the wing. I may have to add another .5OZ of lead.
I didn't expect that much difference.
#403
My Feedback: (102)
That one is a box head with a bathtub combustion chamber. I received a private offer to trade the Enya .90 for a brand new Saito .80. I just might do er.
#404
ORIGINAL: downunder
Actually what I'd like to know is what's an Enya .49? I've never heard of one.....
#405
My Feedback: (264)
MD
ORIGINAL: Hobbsy
Well, Enya enthusiasts, I had an Enya moment yesterday. I mounted my Enya .90 fourstroke on my Alpha 60 to replace the Saito 1.00 I had on there last year. I sold the 1.00 a few weeks ago. Much to my surprise the Alpha was way nose heavy. Today I spent some time grinding the upper inside corner of the left engine mount to move that engine back 1/2'' and still had to place 2 OZ of lead in the very tail end of the fuse and place the battery at the back of the radio compartment. It still noses down pretty good when I have my bird fingers under the CG marks under the wing. I may have to add another .5OZ of lead.
#406
ORIGINAL: fiery
Just picked up a 2nd hand ENYA 11CX Diesel. What a delight. Looks like it has only been test run. Really good compression.
I tip my hat to ENYA for keeping diesel variants of some of their smaller engines available.
You lucky dog! The Enya .11CX Diesel is one of the engines that I have wanted for a long time. I might just have to get around to buying one soon. I already have the glow version. I wonder if buying factory parts for the different Diesel parts is worth it?
Ed Cregger
#407
IIRC, the .90 and the earliest 1.20 share a crankcase casting, which accounts for the high weight and extreme durability.
Hobbsy, I can't say that I would blame you for trading that .90 four-stroke for an Saito .80. The Saito .80 offers much better power-to-weight stats.
Ed Cregger
Ed Cregger
#409
The G8 version with muffler gives the same power as the G7 without muffler or about 12% more power if both are used with a muffler. An Enya chart I have shows the G7 producing 1.3HP and the G8 with 1.45HP. An engine test by Peter Chinn back in 1973 found peak HP came at 14500-15000 which he described as "outstandingly good".
They're lovely engines but be prepared for a long running in period. Mine has done 80 minutes of running so far and the ring still almost looks like brand new, I could only see the beginnings of smoothing out of the machining marks by taking a macro photo then altering brightness and contrast.
#410
Personally I think Enya rings are too hard, after trying Bowman's product in my 46-4C and 45-2C I can highly recommend them, they break-in with only a few tanks, and you also have the opportunity to custom fit the ring gap to you cylinder for optimal compression.
Mike.
Mike.
#411
1 Post
ORIGINAL: downunder
The G8 version with muffler gives the same power as the G7 without muffler or about 12% more power if both are used with a muffler. An Enya chart I have shows the G7 producing 1.3HP and the G8 with 1.45HP. An engine test by Peter Chinn back in 1973 found peak HP came at 14500-15000 which he described as ''outstandingly good''.
#412
After posting my question I actually looked into the throats of the G7 and G8 side by side. I'm guessing the 7 and 8 are referring to millimeters diameter as you can see about a mm difference in diameter between the two. Quite simple I guess, bigger throat more air, thus more hp. I will have to buy a G8 from Ken Enya if I want to make a twin sometime in the future! Thanks for the performance info downunder.
#413
I would be more inclined to go with another G7 carb or a couple of matched Perry carbs, which could be bought for the price of one G8 carb, I'm sure.
Why? Because I could choose carbs with a lower airflow rating, which would increase fuel suction, improve fuel atomization and would eliminate the need for a pump. All of which would make the engines more reliable running in the long run. Something valued by multi engine operators. That last erg of horsepower isn't nearly as important as engine reliability.
Just my $.02.
Ed Cregger
Just my $.02.
Ed Cregger
#414
Yep, the G7 and G8 refers to the venturi size (mm) and the G8 would require muffler pressure. There was a version of the later G10 on the 60X-4 that used a geared pump.
#415
The engine with the G7 carb must be an early version of the 60IIB because the instructions make no mention of a G8 being available. On the other hand the instruction sheet for the G8 carb engine give specifications for both carbs. The "SPECIFICATIONS" section of the instructions that came with the G8 carb engine tell you that pressurization for the G7 is "needless" and for the G8 it is "needed". This is the only difference in the instructions between the two engines, everything else is word for word the same. The G7 carb engine comes in a black box and only a gold colored label on the top of the box saying "ENYA Engines" and the address of Enya in Japan. The other box for the G8 engine is an MRC version. In the picture of the MRC engine the muffler is a current version. The crankcase was drilled at Enya in Japan. Ken Enya generously offered to drill it for free as I do not have a drill press or extra crankcases if I screwed it up. It was only gone a couple of weeks. This time I will wait for a strapped muffler to show on Fleabay.
Mike
Mike
#416
LA
Thanks Guys for your input.
In reply to NM2K (post 387)....I stand corrected. The dead stick led to the crash whether it was the cause or not. Have tried
different new, different heat gloplugs. Tried it with 10 X 6, 11 X 5 and 11 X 7 props.
In reply to Riddle4u (post 391)...Engine was bought at an estate sale, no paper work. Had some use on it. Tried standard tuning on
the high speed needle, what I use on other engines. Rich to lean several times. Runs fine on the high end. Didn't notice the plug color
but engine seems normal temp when it quits. I don't think the fuel tank is the problem. K & B 40 ran fine on the two planes the Enya
49 would not run on. Probably is operator error as NM2K suggested even thou at the time of the crash, almost a year ago, I
considered myself just past newbie. I now consider myself intermediate. I have tried adjusting the low speed from able to run all the way to nothing. I have went in both directions and end up back at the same spot. That is, the spot where it runs as described earlier.
I will post updates later.
Thanks Again
stumblebum
ama47306
n5ezw
Thanks Again
stumblebum
ama47306
n5ezw
#417
Don't mind me. I'm just an old grouch these days.
Good callsign. My old technician callsign was close to yours (N2ECW). I had it back for a while last fall, but eventually went back to NM2K.
The important thing is that you're not giving up. I wish you much success in solving your problem.
Ed Cregger
Ed Cregger
#418
Yea, Stumblebum...keep with it! I am sure that experience is the main thing. To other conversations on G8 and G7, I assume you're all correct on the throat diameter. I do note that a larger throat is not always consistant with increased HP! It was mentioned that the G8 required pressure and not the G7. This is due to decreased intake velocity which results in lower natural fuel draw (from Bernoulli). You can't have it all.
#419
Downunder, mine is actually an SS .40 R/C BB. I think I got caught up since my first Enya was a .29 R/C. Must be the "nine" part is age-related brain malfunction. Glad you did find a .49X though, in existance. Sorry for the confusion. My brother and I both have some of the last .40 SS BB's sold apparently (in the U.S.). I hope they may become available again as they blow away my O.S. .46 FX! They take some carefull break-in, but continue to deliver year after year! Now that is what I am talking about!
#420
My Feedback: (102)
It was mentioned that the G8 required pressure and not the G7. This is due to decreased intake velocity which results in lower natural fuel draw (from Bernoulli). You can't have it all. (Quote)
Read more: http://www.rcuniverse.com/forum/m_36...#ixzz0pt2dm800
This is something I discovered with my Enya .46MKII in 1990, if I placed a 12x6 Graupner on it, it would have a really fat midrange. Put an 11x6 on and the revs went up and you could run the HS needle about 3/4ths turn leaner and no more fat midrange.
I got pooh poohed a few times for saying it was the lower airflow velocity when using the 12x6 that was the root of the rich midrange. My .53TN handles a 12x6 just fine.
#421
ORIGINAL: Riddle4U
Downunder, mine is actually an SS .40 R/C BB. I think I got caught up since my first Enya was a .29 R/C. Must be the ''nine'' part is age-related brain malfunction. Glad you did find a .49X though, in existance. Sorry for the confusion. My brother and I both have some of the last .40 SS BB's sold apparently (in the U.S.). I hope they may become available again as they blow away my O.S. .46 FX! They take some carefull break-in, but continue to deliver year after year! Now that is what I am talking about!
Enya ran out of the SS40BB G7 engines, but the standard SS40 and SS40BB TN engines are also available.
I know that the yen to dollar exchange rate is bad, and that ordering Enya engines direct from Japan isn't exactly frugal. The engines are so good, however, that the price almost seems meaningless. Should an Enya 50CX cost $75 more than an O.S. .55 AX? Does it matter if the Enya will last as long as five .55 AX engines?
I've only recently been "turned on" to Enya engines, but boy am I ever hooked!
#422
Like you, Big Ed, I too occasionally spend the extra money to buy Enya engines. Yes, they are worth the extra money, which isn't always available to spend, but, when I can afford it, I buy Enya engines as often as possible. Too bad they stopped making my favorites, the AAC series of CX engines.
Ed Cregger
Ed Cregger
#423
PA
Ed there is a .45 CX on ebay with 23 hours to go, the bidding is up to $36 it was never run looks real nice!
Rich another Enya LOVER
#424
Yes, Big ed the Enyas seem to last much longer and give more power. O.S. makes some great engines..for sure but there is something about the metalurgy and fit of Enyas I am guessing, that just results in a little more performance and longevity. I have yet to run my O.S. 120 surpassII with pump (4s). I think I'll like that too.
