TT91 FS overprop'd?
ORIGINAL: Flyboy Dave
In theory the 12-8 and the 14-6 give about the same load, however the
12-8 will allow higher RPM, and more speed due to the increase in pitch.
With the prop sizes that we use, 2" of pitch are the load equivalent of 1" of diameter, so a 14x6 offers the same load as a 13x8, 12x10 and 15x4 props. The RPM will be very close with all these sizes.
A 12x8 will give about the same RPM as a 13x6.
I think that as long as you are inside the engine's prop range you can take 1" diameter and add 1" pitch or viceversa, when you get out of that range, you start taking 2" pitch for each diameter.
Example:
TT91FS -> 11x10 to 13x9 (as the manual says)
11x10
12x9
13x8
14x7 <- we're out of the engines specified range, start decreasing 2" pitch for each diameter
14x6
15x4
Example:
11x10
12x9
13x8
14x6
15x4
I use the prop sweep to indicate volume loading and the results are as follows:
Load
11-10 950
12-9 1017
13-8 1061
14-7 1077
14-6 923
15-4 707
It is also very important to keep the engine in the power band.
Bill
Load
11-10 950
12-9 1017
13-8 1061
14-7 1077
14-6 923
15-4 707
Bill
Joe,
I was not referring to a specific engine and its recommended prop size range, but to a specific prop load.
A given engine should spin at a certain target RPM, to show good performance.
Let's take a certain sport .46 engine, with a muffler. It should be set to a ground RPM, between 12,000 and 14,200, where the higher RPM is for best power and the lower range is for best torque (thrust - 3D).
If we target a certain limited range; say 13,200-13,500 RPM, any prop equal in load to a 10x7 will be spun within this smaller RPM range. It could be an 11x5, 10.5x6, 11.5x4, 12x3, 9.5x8, 9x9, 8.5x10... With each of them, the RPM this engine is capable of achieving an RPM between 13,200 and 13,500.
Of course you can increase the load, but then you will get into a lower RPM subset. If you increase the diameter (choose any of the props in the above paragraph) by 1" and decrease the pitch by only 1", RPM will be down to 12K+, which is in a different bracket.
The engine will no longer be able to power this prop into the previous bracket.
And I am talking about props of the same design. If you use narrow blade props, in the new group, you may be able to stay within the higher bracket, but then it is still a prop with the same load as the previous design 10x7...
The general rule remains; 1" diameter is equivalent to 2" pitch.
Increase one and you will have to decrease the other by this ratio, to maintain the same load.
It wasn't me that invented this...
ORIGINAL: BillS
Load
11-10 950
12-9 1017
13-8 1061
14-7 1077
14-6 923
15-4 707
Bill
Load
11-10 950
12-9 1017
13-8 1061
14-7 1077
14-6 923
15-4 707
Bill
My personal experiernce with engines in the 40 - 90 size, & their associated props, is that 1" of diameter approximates 2" of pitch in engine load. This correlation is best demonstrated with engines that have relatively steep power & torque curves -- they are more sensitive to load, & the RPM changes are more pronounced.
A TT 42 GP is an excellent example. My 42 GP turns 13,000 RPM with an APC 10-6, 11,700 with a 10-7, 13,100 with an 11-4, 11,600 with an 11-5, 10,900 with an 11-6 & 11,100 with a 12-4.
It very nicely fits the 1"dia = 2" pitch correlation.
#32
I'll give the manufacturers 2 choices, they can make the MAS as efficient as APC, or make APC look good
[sm=devious.gif]
[sm=devious.gif]
#34
Banned
ORIGINAL: w8ye
The noise that some of the larger dia Master Airscrews make when on a flyby is awsome. Like a 14-6 on a Super Tiger 90 or a 15-6 on a Y-S FZ91.
Spectators (and fellow fliers) love it.
The MAS/APC debate isn't really that important. Most of today's engines have more than enough power for the airframes they're attached to so it becomes an issue of wallet-size and personal preference ahead of raw performance.
#35
ORIGINAL: w8ye
Enjoy,
Jim
Enjoy,
Jim
Then I think "the energy consumed to make that sound is not contributing to the all important forward motion", which brings me back to "Mother APC" (or Bolly).
#37
MI
The debate of 2" pitch for 1" diameter VS 1" pitch for 1" diameter...
Another factor which many people don't consider is the chord width. *Usually* when diameter is increased, the chord also gets a little wider, as in the case of APC. So APC 14x8 gets about the same rpm as 15x6.
I would like to point out that APC 13" prop is a thin blade sport prop, but 14 is the pattern profile that you see up to 20". So 13x8 APC will actually get higher rpm than APC 14x6.
As for Master Airscrew nylon prop, the tip flexes under load, so a 14x6 is more like 14x6-4. You will get very good rpm with MA 14x6 on TT 91, but the pull won't be as good as APC 14x6.
#38
Agree. It is only an approximation, & as you pointed out, the approximation works for props by the same manufacturer & of the same geometric configuration. It is still a closer approximation than the 1 - 1 scenario.
#39
I use the 1" Diameter 2" pitch rule too - there aren't too many surprises using this approach. Sean, you make a good point on the profiles of APC props. The "Pattern Profile" actually kicks in on the higher pitch 13", 12" and 11" props; for example, the 13x9 and 13x10 are "Pattern" whereas the 13x8 is "Sport".
I have found that loading through this "Pattern/Sport" divide is still fairly consistent with expectation, at least in the 13" diameter range.
#40
OK on the original question here is the real answer from an old retired aerodynamicist. On the original question (airplane and engine combination) if you chose to use other than a 14/6, 15/6, or 15/4 you will suffer a condition known as "chronic unhappiness". When this occurs take a deap breath, sit down, open a cold beer (other than the USA) a cool beer, relax. Go back to using the 3 props mentioned and the " chronic unhappiness" condition will subside.
Denis
Denis
#41
I have a better idea:
1.- Open a Corona and drink it
2.- Open another Corona and drink it
:GoTo#2 until I don't give a damn about "chronic unhappiness"
#43
Gee dude, we don't have any of that stuff down here [:@] we only have:
- Sol
- Corona
- Victoria
- Modelo Especial
- Negra Modelo
- Moose Head
- Bavaria
- Heinekken
- Budweiser
- Bud Light
- Coors
- Miller GD
- Miller Lite
- Gallo
- Gallo Light
- Kloster
- Kloster Light
- Superior
- Pacifico
- Estrella
- Tecate
- Tecate Light
- XX (Dos Equis)
- XX Amber
I think I forgot a few
Now I just have to make a choice
but I think i'll stick to some wine to make me sleepy
- Sol
- Corona
- Victoria
- Modelo Especial
- Negra Modelo
- Moose Head
- Bavaria
- Heinekken
- Budweiser
- Bud Light
- Coors
- Miller GD
- Miller Lite
- Gallo
- Gallo Light
- Kloster
- Kloster Light
- Superior
- Pacifico
- Estrella
- Tecate
- Tecate Light
- XX (Dos Equis)
- XX Amber
#46
I didn't know anybody still used MAS on anything but trainers
#47
ORIGINAL: Sport_Pilot
.....The wooden MAS's will often perform better than other brands...
#48
But after switching over to Bolly wood props, you realize who is the king...
#49
Hugh,
I have only been dealing with them for over two years now...
The Clubman series? I always ream them to size and shave off all the sharp 'casting slag'.
After that, I have not needed to balance even one of them.
...And I do check each and every one of them, with a finger-tip balancer, before selling, or mounting them.
No returned samples either.
You must of encountered a 'quirk'
The woods are a real hit here, as are the C/F.
Most competition participants use them specifically, unless they have to endorse a hobby-shop, or something... who sell another brand...
#50
I tried today a MAS 13x8-K but didn't fly (did it on the backyard), Engine gets to around 9.6K with some smoke, I'll fly it tomorrow with that prop and let you know what happens
