3D prop for YS91AC
Hi there, I have a 4.3 kg/9.6 lb plane that I'd like to hover. My YS91AC with 20/20 fuel and 15x8 has to little thrust. the rpm is now 9500 without exhaust (cause I lost it)
APC does not make a 16x6, would 16x4 do the trick, or will it melt the engine due to high revs in non vertical manovres?
(now, Jake, is the time to come with your expirenses
You will probably find out that he is not even able to order it. I had a similar experience with 14x4W prop.
Originally posted by Propellars
Dang, then It's my dealer that doesnt have it. I'll ask him again.
I just asked him, he can take it home - it'l only take a month or two :-)
so I guess I should'nt depend on that propeller for the future, or by more than one at the time.
