A question about timing
Old 12-07-2002 | 02:39 PM
kkj
Default A question about timing
Is it possibly to estimate what ignition timing a glow plug engine have. I suppose it is before TDC, but how much?
Old 12-07-2002 | 03:24 PM
You can just measure it with a degree wheel, they're all different. Here's a post that talks about it:
http://www.flightlines.com/forum/For...ML/000364.html
Old 12-07-2002 | 05:20 PM
kkj
I don't see how that can be measured. The Fuel ignites by the glow plug. but it is glowing all the time (like an old oil engine).
Old 12-07-2002 | 08:12 PM
Hej!
Varför vill du veta det??? Kan inte förstå vad den kunskapen skulle användas till....Berätta
Hälsningar!
Jan K
Väsby MF
Old 12-07-2002 | 09:12 PM
kkj
Default To the Swedish fellow!
Jag är en "motor man" och bara nyfiken på vilka premisser en 2-takts motor av det här slaget fungerar. En liten glödstiftare är rätt så lik en råoljemoter. Bara mindre och annat bränsle och framför allt, tändningen går inte att styra.
Old 12-08-2002 | 04:02 AM
It's almost (but not quite) impossible to say when ignition occurs in a glow plug engine because of all the variables. However, I have a graph made up by Brett Buck from cylinder pressure readings gathered by Sott Bair in tests done on a Super Tigre 46 running in a 4 stroke at 7500rpm. The graph is actually instantaneous torque at all degrees of crank rotation but it can be interpreted as showing where ignition occurs. The graph shows a sudden rise in torque (pressure) at approximately 25 degrees BTDC.
Old 12-08-2002 | 02:25 PM
kkj
Interesting. That appears to be realistic. It must say something about the engine or combustion chamber efficiency. Now I only have to check with other two-stroke engines.
Why, you may ask?
It can't be wrong to be curious.
Old 12-08-2002 | 02:41 PM
But it can be lethal.
Old 12-08-2002 | 06:35 PM
kkj
Default "nose to close to the prop"
The warning is apprehended
(did I express this right?)
Old 12-08-2002 | 11:50 PM
Close, but not quite. Our police apprehend bad guy's. We heed warnings.
Old 12-09-2002 | 05:32 PM
kkj
Damned! But apprehend has two meanings?
apprehension 1. what police do 2. light fear (sort of)?
My nose apprehend the prop.
Old 12-09-2002 | 07:57 PM
That would be apprehensive. Such as " He was apprehensive about flying his new large scale airplane".
