Simple Perry Pump Test
As a result of a PM asking about whether or not a Perry Pump would stop fuel siphoning, I decided to try it and see. I have two Perry's in service, but on one there is just straight pipes which precludes muffler pressure, and on the other the distance from the tank to the engine is too far. Neither has the tank centerline well above the spray bar. This will be no surprise to folks who have tried it, but may help others decide. On both the VP-20 and the VP-30, the fuel started running through the pump as soon as a head started to develop. My conclusion is a Perry is good for a low tank but not so good when used when the tank is high.
TX
ORIGINAL: TimC
Oh well, some have more time to fiddle around than to fly, I guess.
Cheers,
Chip
Chip, if a person was tempted to use a Perry Pump in a high tank situation, thinking it would regulate the flow and prevent flooding, this test shows it would not.
ORIGINAL: Flyer95
Is it important where the pump body of the VP30 is mounted ? Could it be "too high" or "too low" ??
The VP 30 does regulate pressure, but at a pressure much higher than that from a tank mounted too high. So the fuel pours right through. Perry Pumps were designed for 70's type pattern planes with bored out carbs to supply more fuel with weak vacume from the carbs. They do work well with tanks mounted far from the engine as well. But use a Cline regulator if you want it to stop dripping fuel.
ORIGINAL: wcmorrison
Why would anybody use a pump when you had such good head pressure (e.g. high tank)?
Cheers,
Chip
Cheers,
Chip
Good observation Tim. Perhaps needle valves are closed more to cause any problems IRL. I have taildraggers and when on ground the tank is low and no siphoning happens.
When P30 fails does it fail suddenly or does it decrade gradually?
Sorry for confusion. I understand that is normal even with good and operative P-30. I have got any trouble in my use. I just tried to gain general experience about P-30 which I am planning to use soon after many years. I have one used and one unused which have bright aluminium case so they are old.
TX
Well, I see your fuel bottle and the two pumps. I don't see your test setup. Did you stand that fuel bottle on end and connect it to the Micro Oscillating pump, then drop a fuel line from the pump's outlet a foot or two below that? If you did it that way, you were stacking the deck in favor making the pump siphon.
If you laid the tank on its side and located the pump at a height approximately equal to the tanks location, you'd have it set up like it would be in an airplane. Then, of course, you'd have to connect the pump's outlet to an engine carb, with the throttle closed. Only then would your test approximated a real model installation. Why not rig it up on an engine test stand?
CR
Charley, I said it was a simple test.
I think all I remember doing is filling my fuel bottle, connecting it to the inlet of the pump, blowing on the vent line of the bottle to prime the pump and then raising and lowering the bottle to vary the head on the pump.
TX
ORIGINAL: TimC
I wouldn't do all that again. I'd mount the engine sideways to get the carb on the tank CL and forget all that hassle.
esamart...I have had 2 of my pumps stop working...not sure why, but 1 started pumping bubbles, and the other started dripping fuel out of the weep hole...
I have several pumps that are as old as they can be...from when they were introduced in the mid 70's (K&B backplate versions) and most still work great (I like 'em ) but both of them that "failed" did it suddenly.
