engine is squicking
Old 03-31-2006 | 05:43 PM
Cambo's Avatar
Default engine is squicking
Just statrted my fl 70. Richened the aribleed and runs great. But now the engine is squicking and kills itself instantly at idol. I started it up again but the problem got worse and the squicking was very loud. I killed the engine on my transmitter in fear of something bad happening to it. What the heak is it. Anyideas. I guy at my field said you have to maintain the valves every 20 flights. Could this be the problem. I have one flight on it and have run the engine at least 15 times breaking it in and trying to get it running right.
Old 03-31-2006 | 05:50 PM
w8ye's Avatar
My Feedback: (16)
Default RE: engine is squicking
Try turning it over by hand to see if you can feel any roughness of the bearings or any places it catches.
It an ABC engine. Maybe it's too cold? And you are hearing the piston squeak in the cylinder?
Old 03-31-2006 | 06:09 PM
Flyboy Dave's Avatar
My Feedback: (21)
Also, you might look at the rockers and see if they need oiling. If the rockers
are dry....check the cambox as well.
FBD.
Old 03-31-2006 | 06:16 PM
Cambo's Avatar
Didn't feel any resistance when turning it over and i looked in the rocker arms and from what i saw seemed drenched with oil
Old 03-31-2006 | 06:27 PM
My Feedback: (9)
Sounds like your running too rich and not allowing the engine to heat up and establish good running clearances. A squeek at TDC is normal on a cold ABC engine because of the interference tolerence between the piston and cylinder. When starting a new ABC engine you should bring the RPM to close to max as soon as possible to allow the cylinder to expand to running tolerences. Only other potential problem could be gummed up bearings.
Phil
My Feedback: (21)
What kind of fuel are you using, and what kind of oil does it have in it ?
What is the quanity of the oil in the fuel ?
FBD.
Old 03-31-2006 | 06:55 PM
Cambo's Avatar
Hey guys, the problem was that the prop nut had loostened itself, I tightened it and the squicking is gone.
Old 03-31-2006 | 06:59 PM
My Feedback: (21)
Excellant !!
Old 03-31-2006 | 07:03 PM
Banned
Have to adjust valves after every 20 flights??? Words of wisdom from another "expert".
Old 03-31-2006 | 07:04 PM
Banned
Have yet to see a four cycle ABC that is that tight at TDC.
Old 04-01-2006 | 04:39 PM
My Feedback: (9)
OH! Squicking! I thought you meant squeeking!
Phil
Old 04-01-2006 | 04:57 PM
Banned
Squicking is what skwicks do when you step on one.
Old 04-02-2006 | 04:00 PM
what is squicking? A quick chicken type of sound? As bleeding furriner, please enlighten me.
Old 04-03-2006 | 08:55 AM
Squicking is like squeaking but with a deeper tone. You know, squick, squick, squick.
Regards,
doubedee
Old 04-03-2006 | 08:57 AM
Squicking is like squeaking but with a deeper tone. You know, squick, squick, squick. Generally caused by a loose prop nut.
I don't know what squeeking is. May be a combination of squeaking and squeeling.
Regards,
doubedee
Old 04-03-2006 | 03:52 PM
mscic-RCU's Avatar
I can honestly say that I have never squicked or squeeked. I will check with the wife, but I don't think I have ever done either, though!
