Alternative replacement parts?
IN
I need a piston ring, and bearings for my supertigre G 90. At tower the ring runs $10 and the bearings are $12 and $15 each. Are there any other bearings out there that will work? Perhaps better quality? GMS and "tower engines" also sell replacement parts for their 75 which are significantly cheaper. Is there really that much of a difference in these parts? Supertigre uses the same bearings for their 61-90 and I assume a tower or GMS 75 bearing would also fit. I bet most of these companies order bearings from the same bulk distributor. Any thoughts?
IN
Boca has 18 pages of supertigre bearings. Where do I start? I would like to use this for a higher speed application, but some of these bearings are over half the cost of the entire engine. Anyone have experience or advice?
My Feedback: (16)
I use this guy's bearings. They are real cheap. I havn't had any failures. $7.97 for both bearings together for a G90
http://www.mcintoshcentral.com/rc-be...810022acc37922
I use this guy's rings
Frank Bowman
1211 N. Allen
Farmington, NM 87401
(505) 327-0696
[email protected]
A lot of other people on here do also.
Frank Bowman
1211 N. Allen
(505) 327-0696
[email protected]
