Pls Help Identify Engine
ON, CANADA
Can anyone identify this enging manufacturer? It is about a 60 size, I got it at a yard sale and have no other information on it. Can someone please provide me with some more details. Manufacturer, good bad, reliable worth how much?
That is a type "S" Bluehead engine.
...no sorry i dont know of any manufactures other than SuperTigre or Satio what the S could stand for.
Whatever it is it looks good, seems to have lots of porting going on with all the raised passages that you see on the cylinder block.
I'll keep posting stupid answers to help keep the thread on top till someone can win the prize. Just kidding, they will kick me out for that.
Good Luck
Good Luck
My Feedback: (14)
It resembles a Skyward engine, but I wouldn't bet money on it.
Yes, it does have a Super Tigre carb. The head shape is wrong for an Super Tigre S.40. The block doesn't look like a Super Tigre either. I "think" the Skywards were built by Picco for a while.
Tooks like a Skyward engines with a ST carb swap-out. Skywards were not considered very good engines, which may aco**** for the carb swap.
Dr.1
Dr.1
It is a Skyward Engine, made by Picco which make racing engines. I fould some actual pictures of one. Sorry about the small print, these pictures were only copied, not taken by me.
SKYWARD MODEL AIRPLANE ENGINE .60 ABC (10 CC)
DESIGNED AND MADE BY THE ITALIAN PICCO ENGINE MANUFACTURER 15
YEARS AGO APPROX.
Specifications
Displacement 10 CC (.60)
Type 2 Stroke cycle, Schnuerle Scavenged, ABC glow
ignition
Crankshaft 2 Ball Bearings
Bore24 mm (.945)
Stroke22.1 mm (.870)
Carburetor 2 Needles Rotating Barrel 8.5 mm (.330)
Piston/Sleeve True ABC Type (Aluminum piston with chromed
brass cylinder)
Compression ratio 9,4:1
Horsepower 1.65
Weight 21.0 oz
If you want the product review by Clarence Lee in R/C MODELLER
magazine (January 1992)
YEARS AGO APPROX.
Specifications
ignition
Bore24 mm (.945)
brass cylinder)
Horsepower 1.65
Weight 21.0 oz
