What make is this engine?
TX
I just got this engine on a 1/5 scale scratch built Bucker Jungmeister. I did clean it up and oil the inside. It has good compression. The prop is a 16/6
PS - I know I put the head back on 90 degrees from the way it should be, but I will not run it this way. Just wasn't paying attention.
TX
Thanks for the help. It is a Tartan. From what I have read, they run the same spec glow fuel as the big tigres, 0-5% nitro, and 10% oil. Luckily I already have the fuel for a 3250.
