YS 63 Prop Sizes
Old 06-19-2006 | 03:18 AM
Default YS 63 Prop Sizes
I am putting a YS 63 on a UCANDO 46, and was wondering if anyone has any experience with prop sizes using this combo?
Old 06-19-2006 | 07:38 AM
Default RE: YS 63 Prop Sizes
I have a UCD 46 and had a YS63 on it last fall. A 13x4w worked well. I put an OS 91 4s on it and the YS is now on a 4 lb profile Mojo. The 13x4w may be a tad light on load for the YS . It will rev into the mid 11k rpm range but on a UCD you won't dwell there and the YS can hanle 11,500 ok. The YS will pull the UCD straight up. The OS 91 is a liitle stronger. The next step up in 3d props is a 14x4 narrow which I don';t hear about and a 14x4w which is a tad too much - slower wind up from low revs when you open the throttle.
One guy who does a lot of posting on here used a 12.25x3.75 on his UCD46 with YS 63 and says he liked it better than the 13x4w. I believe you will get more thrust with the 13x4w.
Old 06-19-2006 | 08:22 AM
tuwood's Avatar
ORIGINAL: Jack Hyde
But, it sounds oh so cool revving at 11,500 with the 13x4W.
I'm running a 13x4W with Coolpower 30% heli & I have it a touch rich at 11,700 & it's an absolute screamer on my profile. Love this engine
Old 06-19-2006 | 11:41 AM
Thanks for the input guys. Sounds like 13x4w will be a good starting point.
msouth
