Saito 56 idle problems
MT
I have a new 56 with about a gallon of fuel through it now (20/20YS blend) and I cannot get this thing to idle low enough to not pull the plane around when sitting on the ground. It will idle down to about 2500 for about 10 seconds and then sputter and quit. Ive played with the needle setting, and changed the glow plug to an OS type F all to no avail. Any advise from you Saito guys would be much appreciated.
msouth
msouth
msouth12
Just about anything you'd ever want to know about the basics of setting up Saito engines can be found at:-
http://saito-engines.info/index.html
Good luck.
Runway
Good luck.
Runway
MT
Thanks for all the advice fella's. I got it to idle properly today by continuing to lean the low speed needle as sugested. The motor transitioned perfectly even when it would not idle, so I thought I had the low speed lean enough....I was wrong as it turns out.
