Pipe VS. Ultrathrust?
Old 01-02-2003 | 07:59 PM
Default Pipe VS. Ultrathrust?
Does the Ultrathrust muffler perform as well as a tuned pipe for speed? I'll be running an Irvine .53.
Old 01-02-2003 | 09:01 PM
trailingedge's Avatar
NO.
They lack a few RPM vs a tuned pipe, but they do not have the quirks that a tuned pipe has.
Vince
Old 01-02-2003 | 09:02 PM
Okay...answer a little too short. If you tune the pipe right, you'll get more out of it.
Old 01-02-2003 | 09:03 PM
Yeah that's it....what he said
Old 01-02-2003 | 09:07 PM
The pipe will be more difficult to set up and tune, it wll be more sensitive to peaking as it "comes on" the pipe most likely with a very narrow power band and plug life wll probably be compromised. The advantage of the Ultrathrust or Jett style tuned muffler will be somewhat less RPM, better plug life, less peaky performance and a wider power band PLUS the ease of installation.
Old 01-02-2003 | 10:46 PM
Ernie Misner's Avatar
A simple homemade mousse can setup will function as well as the UT muffler, be lighter, and cheaper - especially if you already have the Mac's header pipe. There are several sites on the web showing how to build one. Let me know if you need the addy's.
Ernie
Old 01-03-2003 | 12:10 AM
Default Pipe
With a properly tuned pipe, just how much stronger would a 10x7 prop run than with a UT?
