Fuel Consumption
My Feedback: (14)
ORIGINAL: JettPilot
Brian,
Gas is WAY easier to use than glow. The engine uses much less fuel, is more reliable, lasts longer, and does not make a oil mess all over your plane. I set the needles on my gas Zenoah ONCE and never have to touch them again, no matter what the weather, etc. etc. Where is the downside to this ????
So what you are saying is that you want to stick with all the hassle and drawback of glow, because you dont want to make a change for the better... You ever used a weed whacker, or lawnmower ? You start them, they run great every time, and you and forget it. Thats gas
Chances are, you are already familiar with gas, you just dont realize it.
JettPilot
ORIGINAL: fireman7875
I am considering a giant scale project and am contemplating power plants for said airplane. In order to avoid straying too far from my comfort zone I am hesitant to use a gas engine and would prefer the familiarity of glow.
Brian
Brian
Chances are, you are already familiar with gas, you just dont realize it.JettPilot
I have often wondered if all of the advantages that you have listed for gas engines (all true, by the way) are one of the reasons that some folks don't use gas engines. They like to tinker! I'm guilty of this sometimes. The expense I could do without, but I'm a tight old geezer anyway.
To me, the no clean up feature of the gas engine is the most important. So what was my last engine purchase? An ASP 1.80 slobber monster. It could have been worse. It could have been a two-stroke.
Gas is easier to use until you run across the model with RFI problems from the ignition system. This can drive you crazy.
My Feedback: (79)
Jettpilot,
I totaly agree with you on the magneto ignition, but then the Zen's are boat anchors by todays standards. Now you just threw the power to weight ratio out the window. I have owned Zens, Quadra's and many many glow engines, but I would prefer the messy awesome sounding four strokes anyday.
My Feedback: (14)
ORIGINAL: MOTORMAN37
Jettpilot,
Jettpilot,
Fortunately, there are still lots of tail heavy bipes and Cubs that can use the Zenoah's extra weight to good advantage.
Not everyone is interested in flying 3D, so the power-to-weight ratio isn't really an issue at all, for many folks.
I'm down to owning two Zenoah engines at the moment - a G62 that is on its way to Ralph's - and a NIB G23 that I snapped up on an impulse. The G23 will one day be recognized as a classic. Someone will want to fly it in a nit of fostalgia and I'll be there to sell them one, at a good profit. <G>
Banned
Don't know about the G23 being a classic but it is a good engine. I have two of them and a G38 in a 1/4 scale L-4. Great engines. My old man is using a G23 in a Balsa USA Dr1.
From: Beautiful Edge of Crater On Reclaimed Mine Land
Good conversation.
SO, the OS MAX .10 FP, in my 72" slope glider (under construction), with a 2 oz tank should run flat out for about 12.5 minutes? That sounds reasonable. A typical 20 second sprint to altitude, soar at idle for 20 minutes, the blip it if necessary on final. That is more economical then gas.
#33
Good conversation.
I think, 12,5 minutes of WOT on 2 oz of glowfuel is very optimistic. Mine had trouble doing 12 minutes on 2 oz at medium throttle
On gasoline, power is a bit down, but it WILL run flat out for about 30 minutes on 2 oz of gas.
The difference is not in the WOT consumption. It is in the lower thottle settings. That FP10 on glow will struggle to idle for 25 minutes on 2 oz, on gasoline (provided proper carburation) it will have zero issues idling for 90 minutes or longer at that same 2 oz.
It is not in the economy (whether you pay 5 cents for a tank of fuel or 10, is pretty much irrelevant), it is about expanding the envelope of what is possible. Maynard Hill allready understood that. If that's your kind of thing, then go for it, if it isn't, stick with glow.
#34
Brutus67,
Thanks for your input. I had heard of such things as running glow engines on gasoline, but thought it only to be a trick and not practical. Having heard your report has made me interested to research it from a truly practical standpoint. I agree, that on a .10, the cost is not an issue for low fuel vs gas (yet?!), but run time per fuel load on a motor glider is an important parameter. Reaching 12 minutes of run time is not so important either, but more run time is very nice to have. I like to run on o% nitro and the .10 likes nitro so maybe gas would improve starting and less than Wide Open throttle settings. I also like to run at lower throttle settings because it seems more scale-like even though I do not go for fine scale, that much.
I am sure all the basic information for converting glow to gas is available here and elsewhere on the 'net, but if you have any salient points of interest on your Eureka! moments would be good to hear if you wish to expound on them.
John Hess '59
Joplin, MO. USA
John Hess '59
Joplin, MO. USA
#35
If you really want to employ CDI, just for the sake of doing it, understandable.
You might however consider using zero nitro methanol fuel instead of gasoline. It will make better power, have no lag transition as well as running much cooler. Needle settings will not be as sensitive. The spark ignition engine will also burn less fuel than it's glow ignition version.
Either way, it's all good.
