twin engines power? is it the same?
My Feedback: (15)
KY
i have read here that the power produced by twin engines is far less than a single cylinder engine of the same size. has this been the case for everyone? i am wondering because i am planning to use some twin cylinder engines in the near future but now, i am concerned that they may not have the power i am expecting. what is your opinion and experiences?
My Feedback: (264)
MD
RE: twin engines power? is it the same?
Our tiny multi-cyl engines will always be at a disadvantage because of the friction from all of the extra moving parts (almost double)over a single of the same displacement. As the engine displacement increases friction becomes less of a factor between the two engine styles.
My OS 120 twin has nearly the same power as my .91 surpass despite a 1/3 increase in displacement.
Banned
Due to internal friction losses small multi cylinder engines have less power than single cylinder engines of the same displacement
I'll tell this story. One of my WM 40 size P-51's has a G90 in it and it is fast. A close friend owns the WM P-82 twin with a pair of 46fx's and that plane blows my "wings" off. Same hold true on another set up. Now this same guy has (but not yet flown) that KMP P-38 with a pair of 91fx's. Should be quite a show.
FL
ORIGINAL: Cyclic Hardover
JettPilot
See for yourself the peak numbers on 15% Cool Power and MA k-type 16x6 prop:
OS FT-160 gemini twin cylinder engine - 9,600 rpms
and following are the numbers of some of the best single cylinder engines:
OS FS-120 Surpass III or E - 8,700 rpms
Saito FA-120s - 9,100 rpms
YS 110 FZ - 9,600 rpms
According to the numbers if YS 110 FZ performs like an 150 sized engine then the OS FT-160 is like an 150 as well. However the big advantage of single cylinder engines is better transition.
Stelios
Stelios
Banned
A twin's "transition" is almost instantaneous. My 120, 300, and 240 four cylinder react almost as fast as I can move the throttle on the transmitter
Where did you get those "numbers".?
My Feedback: (14)
ORIGINAL: JettPilot
The guy in the post is asking about twin CYLENDER engines versus single cylender engines. You are talking about twin engine planes, which is a different stroy alltogether. The twin cylender designs when you get this small are very inefficent. Power will be down, but there is somthing really cool about having a twin cylender engine on an RC plane
JettPilot
JettPilot
Especially someone elses plane when they are competing against you.
Banned
In a scale contest?? You bet. Although judges aren't supposed to take the engine into account in judging, they always do. If you are using a two cylinder or say a five on a Fleet Biplane, the judges usually tend to grade you higher. I know I used to judge scale contests.
