Tower .75 v's ST G90
Old 10-06-2006 | 06:27 AM
Iflyglow's Avatar
My Feedback: (79)
Default RE: Tower .75 v's ST G90
They are within 1-2 oz's of each other. I would have no problem balancing it, but it does not seam like it is more powerfull of enough to warrant it, plus you need a very stable low rpm for landing approaches. My TH .75 idles at 1,800 reliably with excellent transition.
Old 10-06-2006 | 02:01 PM
Banned
ORIGINAL: MOTORMAN37
Well if you try to idle your ST90 that low, your transition will be shot to hell because you'll have to richen the low-speed need a *lot* due to the poor carby design.
ST themselves claim "Any idle below 2,500 RPM is considered good".
I think that probably rules out the ST90 for your application, unless you're willing to put a new carby on it.
Old 10-06-2006 | 06:34 PM
As fantastic as the Tower 75 is (I own two and absolutely love them), there is definitely a very noticeable power difference with the ST 90. I have first hand experience with both engines installed on a SIG Hog Bipe biplane. The G90 pulls the plane with much more authority than the 75.
Regards,
Misterpanda
Old 10-07-2006 | 08:52 AM
Iflyglow's Avatar
My Feedback: (79)
XJET,
If you don't have the idle super low, the Shoestring will keep on flying.[X(] This is a 7lb plane, that is very clean, and is running 8" of pitch.
