mds 2.18
Old 01-16-2003 | 11:53 PM
Default mds 2.18
Easy guys.
Just thought I would mention. I decided on the Moki. I have nothing personal against MDS. I may try an MDS one day. Heck, Horizon gets the money either way. They are the US distributor for both brands.
For the plane I am building, the Moki 2.10 is likely to be one of the most popular engines. This will result in more available information on set-up - mostly from RCU. Also as luck would have it, several of the guys in my club have experience with Moki engines. This eased my concerns about getting the engine set-up and running well.
Moses
Old 01-17-2003 | 12:41 AM
Flyfalcons's Avatar
Default mds 2.18
If you have a tough time with your Moki, then get a Perry VC-30 pump. The 30 bucks for the pump is well worth the hassles you may face without it. However, there are a number of Mokis out there running well with no pump, but you may find the performance increase worthwhile.
Old 01-17-2003 | 12:51 AM
Default mds 2.18
Thanks for the reminder. Just ordered the Cline regulator or Proportional Control Fuel System or PCFS or whatever you call it. I plan on drilling out the clunk as well. I really don't want to deal with fuel draw problems.
Moses
Old 01-17-2003 | 01:23 AM
Default mds 2.18
Hobbsy it'not a story. Really a bad Experience for some of the modeler's in my area. you can believe what you want. I really find it sad that you can not believe some people have had a bad experience with this line of engine. I'm glad you like yours I'LL never own one end of Story!
Old 01-17-2003 | 03:23 AM
w8ye's Avatar
My Feedback: (16)
Default mds 2.18
OH MY, .......WHAT INTERESTING READING?
Old 01-19-2007 | 04:30 PM
  #31
Default RE: MDS 2.18
I lost my manual of the MDS 2.18 and I need to know how to set the low and the High speed needle, how manya turns for each one.
My email is [email protected]
Old 01-20-2007 | 08:25 AM
  #32
Hobbsy's Avatar
My Feedback: (102)
Will, let us know what carb you have, whether the square one with the machined surface on the front or the one with MDS cast into the front and I'll check out my most used one and give you the settings on your style carb.
