Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Glow Engines
TF 1/7th P-51B/D Engine Selection/Scale Outline. Need Help. >
Old 01-24-2003 | 09:59 PM
Default TF 1/7th P-51B/D Engine Selection/Scale Outline. Need Help.
If any of you, guys, have a 1/7th scale model of a TF P-51B/D with a fully enclosed power unit (so that no part is protruded over the scale outline) I would really appreciate if you share your wisdom here. I would prefer modest/cost effective power unit that will allow me to fly scale, no extreme aerobatics involved, but I am open to all options (even converting it to eclectics). I also wondered if any of you have a power unit turning scale 20" prop, if it is at all possible.
Although, I could not find any related material on this board, I must missed some thread and if you know a location where this subject was already discussed – please let me know.
Old 01-24-2003 | 11:25 PM
I fly the TF (red box) P-51B (Shang ra la/Jim Gentile) Mustang with the ST-61 inverted and the head right behind the small air scoop under the spinner. It looks really good except for the mufler.
Old 01-25-2003 | 03:01 AM
My Feedback: (28)
Hey Rusyan,
I think an engine like the st61 would work fine if it weren't for that pesky muffler ruining a scale look... I'd try to find something like that but maybe in a rear exhaust version (MVVS .60?) and use either a pitts muffler or pipe (I'm pretty sure you could hide it in a custom-made bellypan). If it were me, I'd stick with either a 4c or a gas engine.... but that might not look scale!! --just some Ideas!
jilayu udachi
Old 01-25-2003 | 07:27 PM
Hi!
The MVVS .77 or .91 could be used because these engines have a small steelsilencer a an option and they are also made in a rear and side exhaust configuration (an option you have with every MVVS as they use a split cylinder housing).
You could see them at this site
http://hem.passagen.se/airracing
Regards!
Jan K
Sweden
