OS .40 four stroke
Old 12-14-2006 | 10:26 PM
Default OS .40 four stroke
Looking for a plug wrench that will fit the OS 40. None of mine will fit into the cylinder head (too large)
Any suggestions.
Old 12-14-2006 | 10:32 PM
AMB
Default RE: OS .40 four stroke
I picked up a cheap one at the LHS and just used a bench grinder to reduce the outside diameter not pretty but it works martin
Old 12-14-2006 | 11:14 PM
w8ye's Avatar
My Feedback: (16)
I bought a 5/16" nut driver at the hardware store. Didn't have to modify anything. I have probably a half dozen different 5/16" ones. They are all different brands.
Old 12-14-2006 | 11:28 PM
G'day Mate,
A standard 8mm socket, is the right size for glowplugs.
I use one on a screwdriver type socket handle, won't strip threads, not enough leverage.
Old 12-14-2006 | 11:36 PM
w8ye's Avatar
My Feedback: (16)
An 8mm socket and or nut driver is .0025" larger than a 5/16" but will work fine with no more torque than you are using if that's what you have.
Old 12-15-2006 | 12:25 AM
G'day Mate,
A glowplug, is 8mm AF, or 5/16AF, that's Across Flats, measure a plug & see for yourself.
Old 12-15-2006 | 01:47 AM
My Feedback: (264)
ORIGINAL: w8ye
You are right, but that's really splitting hairs
Old 12-15-2006 | 02:12 AM
w8ye's Avatar
My Feedback: (16)
Well, it started out that I thought there was a much bigger error. My math was wrong.
I went back and corrected the actual difference (Which there is little difference)
I was just trying to smooth out my mistake.
The 8mm should work just as well as a 5/16"
