tt 46 pro
Old 01-30-2003 | 12:39 AM
Default tt 46 pro
do most of you remove the baffle on these and does it become alot louder
Old 01-30-2003 | 01:19 AM
Default tt 46 pro
Leave the baffle in . Just take a grinder and widen the vents and grind every thing smooth.
Old 01-30-2003 | 02:00 AM
Gene Chernosky's Avatar
My Feedback: (182)
Default tt 46 pro
I take the baffle out and then, slowly, a little at a time, drill out the exhaust tube on the muffler so it has a constant ID. Yea, it IS a little more noise, but the RPM's are what I'm looking for.
Do what you need to do to make your situation best.
Old 01-30-2003 | 02:18 AM
Default tt 46 pro
I remove the muffler, remove the baffle and toss both in the trash. Then install a $12.99 Tower muffler for a 600-900 rpm increase.
Old 01-30-2003 | 02:32 AM
Razor-RCU's Avatar
My Feedback: (50)
Default I thought so-
Caf- The Tower muffler works well on the TT pro?
I think I will try both just to see what RPM's I get with each-
james
Old 01-30-2003 | 06:45 PM
m.gramling's Avatar
My Feedback: (8)
Default tt 46 pro
I use a moosecan muffler on my TT46, much more power than stock, and about 1000more useable RPMS than tower muffler,
You can build you moosecan for about $25.00
If your interested look here on RCU for them and you will find a ton of info.
Old 01-30-2003 | 07:24 PM
Default tt 46 pro
look at the morris rossi pipe works marvelous for about 40$
Old 01-31-2003 | 02:25 AM
Default tt 46 pro
You will pick up a little rpm with removal of the stock baffle, more with installation of the tower muffler as it has a small tuning effect. The performance specialty muffler I am told is slightly better yet and close to a tuned pipe in performance. For the money the tower is great just make sure you locktite the rear nut.
Old 01-31-2003 | 04:08 AM
Default more rpm's
On my TT Pro 46 I use the towerhobbies muffler, 15% coolpwr, 10/6 apc, and an os #8 plug. I get 15000 rpms on the ground, but,,..,.,.,.,,,.,.,. with that kind of rpm, my engines will not last forever..... I would try the mouse can pipe, but i am sooo lazy, where can I buy one...do they have a mouse can arf?? lol
Old 01-31-2003 | 05:02 PM
m.gramling's Avatar
My Feedback: (8)
Default tt 46 pro
firefighter,
I will sell you a new one for $32.00 plus shipping for a TT46.
Old 02-01-2003 | 10:02 PM
Default $32.00
is that brand new???? what else you selling.
Old 02-02-2003 | 10:11 PM
m.gramling's Avatar
My Feedback: (8)
Default tt 46 pro
Here is the picture of a moosecan setup that I am using on my TT46.
