Fuel Tanks
Old 02-03-2003 | 02:08 AM
Default Fuel Tanks
What is the best way to run your fuel lines inside the tank,When the engine is inverted?
Old 02-03-2003 | 04:39 AM
whstlngdeath's Avatar
My Feedback: (15)
Default tank lines
There is no difference on how you plumb a tank on a inverted engine. What you might have to change is the position of the tank
itself. You still have to make sure the centerline of the tank is at the same level of the centerline of the carb. Or pretty close to it.
Jesse
