cant idle
Old 01-22-2007 | 02:02 PM
mrbee's Avatar
Default cant idle
i have a como .46 engine, idles very fast , can someone explane how to set these screws on this model, thanks
Old 01-22-2007 | 06:29 PM
w8ye's Avatar
My Feedback: (16)
Default RE: cant idle
There's a small screw on top of the carb with a spring under it. Loosen this screw some and see what happens? It is the idle speed screw. Most present day engines do not have this screw.
The COMO was made by Super Tiger. The parts are interchangeable with a Super Tiger the age of your COMO.
The new Super Tigers are coming from China with this screw missing.
Old 01-23-2007 | 08:52 AM
mrbee's Avatar
thanks , so is the l shaped rod next to the fuel line the ajustment for fuel? and on the left side there is a screw next to the intack, what is that one 4 and last, the screw that is connected to the throttlerod ? thanks this is all new to me
Old 01-23-2007 | 09:00 AM
pettit's Avatar
My Feedback: (23)
Maybe the best thing for you to do is look up a flying club and ask one of the more experienced members for help.
It can all be explained here in the forums, but it's a lot better to get help in person, if possible.
Or, "...you'll shoot your eye out..."
Old 01-23-2007 | 09:05 AM
Hobbsy's Avatar
My Feedback: (102)
The L shaped rod is the highspeed fuel flow adjustment, the low speed is directly across from it.
Old 01-23-2007 | 11:02 AM
mrbee's Avatar
thank you very much
Old 01-23-2007 | 11:32 AM
w8ye's Avatar
My Feedback: (16)
The "L" shaped rod in the older engines had a friction nut that limited it's freedom. You can adjust the nut to where the needle is just batrely movable so it doesn't vibrate out of adjustment
Old 01-24-2007 | 06:58 AM
Dave :^)'s Avatar
Hi all
excuse the crappy old carb in the pic but it's one I had handy.
Hope this helps.
Dave :^)
Old 01-24-2007 | 07:03 AM
w8ye's Avatar
My Feedback: (16)
The carb in the picture is an older Super Tiger carb, hopefully, like the one on fallover's COMO?
Old 01-24-2007 | 09:35 AM
mrbee's Avatar
yes exactly, what does the barrel nut screw do? and thanks for the pic, this is my first engine
Old 01-24-2007 | 10:20 AM
Motorboy's Avatar
ORIGINAL: fallover
To hold the barrel at place in the carburator body.
Jens Eirik
