Enya 35V
Old 02-05-2003 | 11:32 AM
Default Enya 35V
Hi,
I've just picked up a used Enya 35V engine, but with no manual. As such I have a couple of questions.
Is the V model much different to the 35X?
What does the little slider do on the muffler?
Is Model Technics fuel (Klotz Synthetic) 10% nitro ok, or should it be 5%?
Whats the best prop to use on a pizza box flyer: a 9x4, or 10x4?
Many Thanks
Andy, UK
Old 02-11-2003 | 06:27 PM
Default Enya 35V
Yes the V model is very different in overall design. Two different motors.
The slider on the muffler is part of the throttle control system. The engine of today uses a standard muffler and carb arrangement. You can replace the valve with a regular muffler and pressurize the tank.
5-10% nitor no problem. 20% oil is recommended.
I would use a 10x4. I like bigger props and less pitch.
Jeff G
Old 02-15-2003 | 01:54 AM
Default Slider on muffler
It's probably placed there so you might be able to prime the cylinder to aid starting .
