Glow Plug worries
My Feedback: (102)
RE: Glow Plug worries
That my friend, is more important than all the brand loyalty in the world, what works is best. I'm still going to test a few plugs since I like to do that stuff.
My Feedback: (21)
The Fox Miracle plug and the OS "F" plug are for all intents and purposes identical.
I see the Fox plug has gone up 90 cents in price....they were $3.59 forever. Contrary
to popular belief both plugs are medium temp plugs, not hot plugs. The Miracle plug is
designed to replace idle bar plugs in two strokes. I haven't used an idle bar plug for
over 20 years.
http://www2.towerhobbies.com/cgi-bin...LXG907&P=#tech
http://www2.towerhobbies.com/cgi-bin...?&I=LXCB28&P=M
Years ago OS refered to the "F" plug as hot, but no more.
FBD.
over 20 years.
FBD.
#32
My Feedback: (9)
Sorry, Buzz. We'll have to agree to disagree. I proved otherwise today which is what got this whole thread started. 31 post plus more possible within 20 hours....a lot of us have a different opinion than yours. It may well be that your ST engine runs with any plug with no differnce, but I'm not so lucky. Changing plugs in mine is like tuning knobs on the fawcett...it's either hot or cold. It made a HUGE difference. I'll try a Tower plug when I place my next order and we'll see how it does, and you could be right. But the other plugs I used up to this point are of no use in this particular engine.
#33
My Feedback: (102)
Daver, in my opinion the Fox Miracle is as close you can come to a universal plug that will work in anything, the only other plug I would include in that catagory is the Enya #3, it's a winner in all respects and also edges out all comers for longevity.
#37
ORIGINAL: outacontrol41
By the way, for those that were wondering: I'm using Omega 10%...
I am glad you got your issues solved.
Try changing your fuel to 5% nitro and closing both needles a bit more.
You might get even better results.
This engine was designed in Italy, with FAI fuel in mind. This means high compression and most people (although, not all of them) who are having 'carburettor problems', are trying to run the 15% nitro that is so popular in the US.
#38
IN
FBD I know that is the newest OS hot -cold chart but I think is kinda whacky. You could also take it as between the 2 specialty plugs the F is hotter than the RE
#39
My Feedback: (9)
DarZeelon,
I'll give it a try, though I've never used anything less than 10% it's worth a try. I'm starting to like this engine now. I've always bought brand new O.S. and Saito engines and broke them in myself. Following owners manual I've never had a moment's problem with these brands. Then I went and bought out an older gentleman's surplus of RC equipment that he gathered over a 20 year period. He got out of it (RC hobby) and in the package was this engine which I knew nothing about. Super Tigre is not something I'm familiar with...but thanks to this forum I can possibly now pass for a Super Tigre salesman...or not. Anyway, I don't mind trying different things at this point as long as I can get back to where I was. This engine pulls around a .60 sized 'Dragon Lady' from Hobby People? I think and it's a real floater of a plane. If the idle is set to high the plane floats right by me slowly with no intentions of landing. That's why it's so important for me to get the idle down low and reliable for slow safe landings.
It's been windy here in Maryland for the last few days...such is January[&o]
Can't wait to get this bird up in the air!
#40
My Feedback: (14)
ORIGINAL: DarZeelon
Outacontrol,
It is 9:30 AM where I am at....
Although Jim, Ed and Dave are experienced fellows, I suggest you first try a cold plug.
A four-stroke plug, like the Fox Miracle, or the OS F, are hot, so as to retain their heat during non-firing cycles.
But, because of their longer 'nose', they behave colder than they really are.
So, in some larger engines, they keep the fire lit, without causing undue detonation, as an OS A3, or an Enya #3 plug may. As to the OS A3, it is said to be a good plug for some four-stroke engines...
I have very little experience with this specific ST engine.
Outacontrol,
I have never knowingly used an OS A3. I'll have to pick up a couple and give them a try. You can't have too many tools in the tool box.
Ed Cregger
#41
My Feedback: (14)
ORIGINAL: Hobbsy
don't flame me it was only for baffled pistons. (quote)
Speeds, I've been barbed before too, for recommending a Fox IdleBar plug, people saying that the idlebar "keeps the fuel away from the fire" what a load of bull, the idlebar on the Fox plug is the equivalent of putting a 2x4 across a 25 foot barn door. Any two stroke you can think of will run fine on a Fox IdleBar plug. It's the only plug with which my MDS .48 will transition well.
Conversely, many engines show a few hundred rpm decrease in top end with an idle bar plug. That's why they aren't as popular as they used to be.
I keep a few around for my baffle piston engines and for an occasional special application with a schneurle ported engine. It is just another tool in the tool box, as far as I'm concerned.
Ed Cregger
#42
IN
You guys can say what you want-But I stock only 2 plugs in my field box. They are the FOX RCLONG and the FOX MIRACLE. The miracle plug is for 4 strokes. Yes if I was limited to only one plug it would be the miracle plug. Just about everything in this hobby now is from JAPAN ,CHINA, TIAWAN , VIETNAM, AUSTRIA ,ECT. I take pride in using an american plug. I tune for the plug -not plug for the tune. I'm not sure if K&B are made in america but that would be my second choice. I get a kick out of my fellow members telling me you need alot more than 5% nitro and can't believe I'm running those crappy FOX plugs. This is their opion passed down from magazines and hobby stores. I have tried other plugs and yes they worked fine. But I choose FOX because of my wide veriaty of engine brands and sizes . I got 2 new magnum 4 strokes coming and they will see MIRACLE plugs. OK I vented-WHEW
#43
My Feedback: (102)
You dun good. The shrouding around the Miracle's heating element does not automatically make it a hotter plug, it just retains whatever heat it had longer because it's protected from the intake charge.
#45
My Feedback: (9)
ORIGINAL: speedster 1919
#46
My Feedback: (14)
I ran Fox plugs for decades. Then I bought a full card of Fox plugs where half of them were DOA. That does something to you that never goes away.
Ed Cregger
#47
My Feedback: (102)
The only time I've had trouble with a Fox plug is when I accidently plug the Glow Driver cord into the 12 volt sockets on the Power Panel, the OSf is the only plug that will stand that.
#48
IN
ED I did have 2 RCLONG plugs this year that worked one run and lost contact. I pitched the plugs and figired it was a bad batch. They last all season and I replace at the start of the year. If I get a new engine I breakin with the plug it came with and then switch to FOX or If I get a used engine I automaticly put a new FOX in it.
#49
Hobbsy-
The Saitos run well on the SS plugs when breaking them in. I pull them after the break in. I'm hearing more people speak well of the SS plugs in both 4 and 2 stroke engines. I have a few on hand now for replacing in my engines. They are about half the price of an OS F or 8. One guy at our field is running his Evolution .45 on a SS. I need to listen to it running as those run cold with an OS 8. He is good with engines and it sounds like the SS is hot enough from what he told me.
#50
Banned
However, the Miracle plug can't hold a candle to the OS-F when it comes to 4-stroke engines. The OS-F makes the needle less critical and allows a much lower idle on all my 4-stroke engines (Saito and Thunder Tiger).
The Miracle doesn't work well in any other engine I have either. In my ST90s it results in about 400 RPMs less on the top-end and a real rough mid-range when compared to a good old OS#8. The strange thing is that an OS-F works really well in the ST90, as does the OS#8.
So, unless I get a real good deal on the Fox RCLong, I just use OS#8 in my 2-strokes (really hard to beat and they last almost for ever) and OS-F in my 4-strokes (same longevity).
Mind you, I only run 5% nitro in my 2-strokes and 10% in my 4-strokes, that may have some bearing on things.
